Philips Wireless Speaker TAW6505
    I got this wireless speaker with no connectivity BT or Wi-Fi. First problem was at the 240Vac connector cold solder and the speaker won't power up. After re-soldering the connector the speaker turn on without any sound, ambient leds flashing and Wi-Fi and BT leds flashing. I got sound from AUX port. Put in pairing mode on phone I can't found the wifi network. Same thing its happening with BT.
    Re: Philips Wireless Speaker TAW6505
    I suppose you done most of these steps , but anyway :
    -Try to release the paired status to any other previous devices already paired with .
    -Try to restart , reset , shut down then open the device you want to link to .
    -Try to remove the paired status from the device , and then add it again .
    - \If there's an internal battery pack , (my older Philips speker has one) , be sure it's full and not damaged .
    If all those fail then you need to show us close and clear pictures of the inside board .
      I will comeback later with some pictures of the board
        Pictures from inside of speaker
          From pictures , it looks like a perfect board , with no stress of any kind .. I suggest you read carefully this manual , especially the update from USB part , and the G5 interference if any , as well as the other instructions .
          Using AUX successfully is a good symptom , and leave doubt only in the Phorus card basically .
          Do update anyway ..
            Thanks for your reply, I wish to make an update but I don't have the files
              You have to register your product to get support :
              www.philips.com/support
