Pioneer Elite VSX-52 DSP EEPROM
  • nodols
    • Jan 2023
    • 24
    Alright had to make a thread for this receive as I felt like the other one was not really for this specific model.
    Would highly appreciate it if anyone has the bin dump for this EEPROM on this specific model number.
    The circuit is Location: IC9004 and Make is: MX25L1606E.
    The IC is quite easy to get to as it is on the top side of the pcb, popping the cover off and it's there for the world to see.
    I flashed the IC with another Pioneer model and I got sound, only thing is that FM is now all out and funky. Basically tunes in to every single frequency and doesn't give sound. All other functions, CD, HDMI ARC, DVD, etc works. Just the FM is off.
  • R_J
    • Jun 2012
    • 9515
    Re: Pioneer Elite VSX-52 DSP EEPROM
    I have that file where I changed the version number, do you still want to try and see if it will update?
    • nodols
      • Jan 2023
      • 24
      Hi Sorry for late response. Sure, I'll try it.
      • R_J
        • Jun 2012
        • 9515
        Are you on right now?
        • nodols
          • Jan 2023
          • 24
          Yes.
          • R_J
            • Jun 2012
            • 9515
            Did it work?
            • nodols
              • Jan 2023
              • 24
              Did it work?
              Hi R_J, could you please upload it again? I had to go out,.
              • R_J
                • Jun 2012
                • 9515
                Yes the file is for USB update, I bumped the update number up by one so it would not be the same as what was installed. If this method does work. I will leave the file up.
                • nodols
                  • Jan 2023
                  • 24
                  I will do it one more time
                  Well what do you know.. I used the USB method to update it and now it's at 50% and updating. I hope this works.
                  Also, I thought I was going to use a programmer for this? Just the USB update works? Kind of baffled. Anyway it's still updating will update if this fixes the FM issue.
                  • nodols
                    • Jan 2023
                    • 24
                    Well.. shame.. FM issue is still there. Firmware at 1-204087119093. Makes me think this is really a problem with the FM module?
                    • R_J
                      • Jun 2012
                      • 9515
                      How do the AM stations work? if they are ok I suspect it is not in the programming.
                      So all it took was to change/increase the internal firmware number by one and it installed.
                      • nodols
                        • Jan 2023
                        • 24
                        Amazing. AM is the same. Says tuned to any frequency and doesn't give out audio.
                        • nodols
                          • Jan 2023
                          • 24
                          It's amazing though that it keeps on updating even with the same file in the usb. You should leave the file up. As it works as intended. Now I'm thinking there is really something wrong with FM and AM being tuned in all the time. CD, DVD and other inputs work. Just the tuners are out with no sound.
                          Oh, before this I had to replace the mux IC as it was popping when I turn the volume up or down. That solved the problem, but spun out a new issue..the FM AM.one.. not sure if its worth mentioning bought the mux IC from ali, as it was no longer available in digikey.
                          • R_J
                            • Jun 2012
                            • 9515
                            Does this "mux" ic you replace have a location number ie: ic??
                            I thought all you did was reprogram the eeprom ic, did you not make a backup of the original before reprogramming it?
                            Do you have V+9T (9v) on CN954, Pin7 going to the tuner module?
                            • nodols
                              • Jan 2023
                              • 24
                              BD3473KS2 IC2501 . It is supposed to be the volume IC. Preamp / Selector.
                              Unfortunately, I didn't have the programmer back then when I updated the firmware from USB. So I don't have the backup.
                              Also, I can't get to the module without disassembling everything. There are 3 PCBs stock on top of the other.
                              I did try to remove the FM module to see if it the problem is removed with the module disconnected and was clumsy enough to turn on power with some cables disconnected. Now the receiver has the blinking blue light.
                              I'm thinking it's in protect due to the connector disconnect and me power it up.
                              I have connected everything but still the blinking blue led is there. So I'm thinking I needed to wait for the large caps to drain to reset it.
                              Unfortunately again I can't drain those caps as they are on the most bottom part without again dismantling everything. What joy.
                              • R_J
                                • Jun 2012
                                • 9515
                                I must have a different service manual, I have the one for the VSX52TX and the tuner is mounted to the back panel near the top. and it plugs into the board labeled AC
                                I would check all the plug connections and cables to make sure there are no bent foils on the cables, Also on these receivers ALL the rear screws need to be in place for proper grounding.
                                Looks like the supply for the tuner is through Q3901 (V+5_T) +5v to CN3902 pin 8
                                • lotas
                                  • Jan 2016
                                  • 4459
                                  • Russia
                                  R_J here is the service manual you need.
                                  • nodols
                                    • Jan 2023
                                    • 24
                                    It's not a TX. Yup, the one that lotas posted. That's it.
                                    • nodols
                                      • Jan 2023
                                      • 24
                                      I removed the tuner module, and true enough no more crazy tune to all frequency issue. Could this be the tuner? Or just the programming that's messed up?
                                      • R_J
                                        • Jun 2012
                                        • 9515
                                        Is the module getting supply voltage?
                                        Try entering service mode and check that the model is correct, other than that I guess it could be the eeprom data, If the tuner worked before the eeprom data was changed, it might be a suspect.
                                          HP Elite Elite 7200 MT Elite 7200 i5-2400 Specification for Upgrade or Repair
                                          This specification for the HP Elite Elite 7200 MT can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite 7200 MT boardview and Elite Elite 7200 MT schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          09-12-2024, 03:44 PM
                                          HP Elite Elite Slice Elite i5-6500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Elite Slice can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite Slice boardview and Elite Elite Slice schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
                                          HP Elite Elite Slice (ENERGY STAR) Elite i5-6500T Specification for Upgrade or Repair
                                          This specification for the HP Elite Elite Slice (ENERGY STAR) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Elite Slice (ENERGY STAR) boardview and Elite Elite Slice (ENERGY STAR) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that...
                                          HP Elite Elite Slice Elite i3-6100T Specification for Upgrade or Repair
