Replacement transformer for Samsung fridge
  • unimatrix93
    • Oct 2021
    • 343
    • Magyarország
    Dear forum
    My Samsung fridge died from a fault on the mainline and the transformer (https://www.hqelektronika.hu/hu/halo...-w8-da2600009k) died.
    No voltage on the secondary, measuring resistance shows open circuit. I concluded a blown fuse which is deep inside the transformer, I don't think I can disassemble it to replace the fuse.
    The second problem is that I cannot find an original replacement part anywhere or even If I do it's pretty expensive.
    My question is: Can I replace this transformer with a generic 230V to 17V one? The output has 4 wire and most that I can found on local suppliers like TME has only 2 like this one: https://www.tme.eu/hu/details/tszzba...szzba-65-002m/
    Thanks in advance!
  • CapLeaker
    Leaking Member
    • 8146
    Huh? The heat fuse is in the primary, not in the secondary side of the transformer. I highly doubt the secondary is open. Check that transformer again.
    Doesn’t matter what you put in order to replace it as long as you get the voltage you need to all the voltage rails. Probably the low voltage AC gets rectified into DC on the board the secondary of the transformer plugs into. Let’s see… 16.5VAC x 1.414= 23.3VDC. I suppose you could take the rectifier diode out and place a 24VDC switching power supply. Possibilities to do a hack, no problem. You just got to understand the circuit.
    • Agent24
      I see dead caps
      • Oct 2007
      • 4951
      • New Zealand
      If it has 4 wires it probably outputs two different voltages.
      If you analyse the circuitry it connects to, you can probably guess what the other voltage is supposed to be.
      Then you could probably replace it with two different transformers supplying each the different voltage.
      -David VanHorn
      • unimatrix93
        • Oct 2021
        • 343
        • Magyarország
        After some digging I found the diagram of the fridge:
Name:	Képernyőkép ekkor: 2025-07-14 13-08-05.png
        It looks like it produces 16.5V and 13.5V on the two secondary.
Name:	Képernyőkép ekkor: 2025-07-14 11-45-36.png
        • CapLeaker
          Leaking Member
          • 8146
          So one rail makes ~24VDC and the other around 19VDC. I guess there must be some rectifiers on the main board. However, it may be easier to fix the thermal fuse in the transformers primary, unless you got a PSU that outputs 24V and 19VDC simultaneously.
          • Agent24
            I see dead caps
            • Oct 2007
            • 4951
            • New Zealand
            You have to be sure there's nothing using the 60Hz AC signal from the transformer as a time/clock reference or something too, if you decided to use a DC power supply instead.
            If you can't fix the transformer, two separate ones should work too.
            Also have to wonder if some fault on the main board overloaded and killed the original transformer.
            -David VanHorn
            • unimatrix93
              • Oct 2021
              • 343
              • Magyarország
              I see, thank you for your input.
              Can I use these two transformers?
              https://www.tme.eu/hu/details/ts10_3...ndel/ts-10-30/
              https://www.tme.eu/hu/details/tszzba...szzba-19-001m/
              • unimatrix93
                • Oct 2021
                • 343
                • Magyarország
                Well you are right about the thermal fuse, but the problem is that it seems its buried deep inside the transformer, I don't think I can disassemble it to get to it.
                • CapLeaker
                  Leaking Member
                  • 8146
                  Just give it a try. It’s broken anyways…
                    09-07-2024, 05:50 AM
                    09-06-2024, 11:40 PM
                    09-06-2024, 08:40 PM
                    Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                    This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                    09-06-2024, 06:20 PM
