Ho crap... I just noticed the Line Freq input is missing a pad on the connector socket, it got ripped when I removed the connector from the board to put it on the hot plate.
Could it be... the pad was already damaged, and the "line Freq" signal was missing before.... causing the Vline to not be detected (or software not checking Vline if Line Freq is out of range) ??
There is a code (C93) to show line frequency, but it's not implemented on this model, I'm 100% sure I wanted to check this code and could not.
I' know I did check line Freq signal before, not sure I checked it on the connector or on the track that goes to the cpu... It was probably on the connector header itself, so no way to tell if the signal was properly routed to the cpu.
Now I'm wondering If I should re-solder the original CPU & connectors and run a wire to fix this and give it another try or wait for the new cpu... dang...
I think I'll refit everything and fix the track.
