SCHLEUNIGER CO207 - Potentiometers on the PCB out of adjustment. How to set them?
  • bpjl
    • Jun 2016
    • 28
    • Polska
    I need help setting up the cable stripper - Schleuniger CO207.
    After contacting Schleuniger directly and their distributor for Poland - Kabeltch, I received 2 PDFs with instructions/documentation. Many thanks to both companies for this help. In these PDFs there are instructions for setting up and calibrating individual components of the device, but my problem lies on the PCB.
    Well, the person who used this device before turned all five potentiometers on the PCB, which caused the Schleuniger CO207 to go crazy. Of course, no one knows how they were originally set up and there is no such information anywhere.
    Maybe someone has access to such a device, could open it and measure these potentiometers? On this basis, I could set the same resistance at home and it would be a good start for further setting CO207.
    • Jul 2011
    • 6070
    Re: SCHLEUNIGER CO207 - Potentiometers on the PCB out of adjustment. How to set them?
    Here is something you could try as a starting point
    Put all pots in the center position and determine what pot adjusted does what and then adjust in one direction and see the results and then turn it in the other direction and determine about where it should be now some pot controls might be for speed and some might be for how far something travels need to make a chart of what each pot controls
    This is what I would do if you can not find a manual for this device
    If you have the setup procedures can you post them I might be able to help you with them
    • bpjl
      • Jun 2016
      • 28
      • Polska
      Thank you for your response.
      I forgot to attach the instruction files to the previous post. I'm making up for it now and attaching both versions I got.
      As far as setting the potentiometers in the middle position is a pretty good idea. I've already tried to figure out which potentiometer does what, but without much success.
        • Jul 2011
        • 6070
        What happened to the machine for the pot controls to mess with
        When adjusting a pot control you need to figure out what that pot control does for it to make sense where you see the paint blobs are is a good place to start from ( but this depends on how many turns you have to make for a change to happen )
        By any chance did you losses the memory of the machine and this the reason for messing with the pot controls this is a no no especially with a machine that has a memory cells it is going to very difficult to get those pot controls to be set correctly I am not saying that it is impossible but you are going to have a lot of patience doing this
        What should have happened is if it lost the memory is that you go through the recalibration procedures and when you have it for the most part function - mostly - correctly - working then you adjust the pot controls ( but this should be the last thing that you would want to do ) but only enough for it to make a change if no change is not noticed move it back to where it was originally and go to the next pot control and so on until you have the machine working correctly again
        Here is my guess to what one of the pot control does is it might control how much force is applied to the cable that is being stripped one pot control might be for motor speed if this is the case then only adjust this pot so has enough speed to strip the wire ( the force one should be adjusted so that it does not go into the wire it self ) the other pot controls might be for other motors if it has more than one
        • bpjl
          • Jun 2016
          • 28
          • Polska
          The whole situation started with a problem with the cable grippers. After the work cycle was completed, they did not let go of the cable.
          My colleague from work, instead of coming to me and asking what to do about it, decided to solve the problem himself. He partially disassembled the gripper mechanism as well as the area around the sensor assy. Cleaned, put together without any calibration instructions.
          As you can imagine, it didn't solve the problem, it only made it worse. Then he noticed these 5 potentiometers and started to spin them completely pointlessly.
          I already set the grippers properly and they work fine. Unfortunately, all the rest of the regulation is completely messed up.
            • Jul 2011
            • 6070
            The issue with these pot controls is that they are multi turn pot so you need to determine how many turns dose it take to go one travel direction to the other direction and then divide by two and start from there ( or use an ohm meter to do this part ) but like I said earlier this is going to take time to get them back where they should be
            One note if these motor are stepper motor then this is going to be harder to do but not impossible to do but adjusting it is going to be a little different than a regular motor would be
            With stepper motors you want the motor to run smoothly and not jumping or chattering so one pot control might be for jumping/chattering and one pot control for steps per second which would be for speed and there might be for torque as well this is a little bit hard to adjust and get correctly done so it works correctly
              • Jul 2011
              • 6070
              Explain exactly what is the issue with what it is doing
              • bpjl
                • Jun 2016
                • 28
                • Polska
                Completely does not keep the set length and diameter of the cut. And I can't make sense of it.
                  • Jul 2011
                  • 6070
                  Check where the battery for the memory now it might not be battery it might be a memory chip ic with a battery inside of ic chip and you would have to replace the ic chip
                    • 31289
                    the pots may be related to sensors to read the cut depth/applied force.
                    i would give it back to the other guy to "fix"
                    or ask the makers for a schematic or service manual
                    • bpjl
                      • Jun 2016
                      • 28
                      • Polska
                      If the problem lies somewhere deep in the electronics, I prefer to leave it to a specialist.
                      My tests show that:
                      1 - set in the middle + two turns to the right - causes the device to start working on its own and works endlessly
                      2 - probably setting the start position of the head (but I'm not sure)
                      3 - I have no idea
                      4 - I have no idea
                      5 - set in the middle + two turns to the left -
                      This is probably how it will end.
                      As I wrote in the first post - I contacted the manufacturer in Switzerland and the local distributor for my country. Both companies only sent me manuals (which I attached to the entry). I suspect that service manuals and diagrams either no longer exist or are a secret.
                        • Jul 2011
                        • 6070
                        They are probably secret and if this the only recourse is do what you are doing with the pot controls until you have satisfactorily results and keep tweeting the pot controls for the best results that you possibly can get and the best that you can do with out the recalibration procedure to get it the way the factory settings
                        One thing that I would also do is do the recalibrate the dies and the tool movements and make sure that they function properly and are easy to move in position and back to the rest position by hand
                          • Jul 2011
                          • 6070
                          Pot number 2 keep turning more than 2 turns in one direction and what does work right then see what happens when you go in the opposite direction and how does it work correctly until you understand what that pot controls do
                          Now for pot controls keep turning one in one direction until either one of two things might happen either something stops working properly then go in the opposite direction until it stops working properly again but watch very closely what stops working properly and when you have how far in each direction it causes it to malfunction then set that pot between the the two ex streams and put it in the middle of two ex streams
                          This would be the best that you can do
                          • Mark R
                            Marantz Model 150 Tuner "NULL" Adjustment..
                            by Mark R
                            I am not ashamed to say this is my first FM alignment I have ever done. I am well versed in electronics and repair. Been doing it for many years on Pro Audio Live sound equipment. Worked on Power amps EQ's musical gear and Large format Mixing Live consoles Etc. But now I can see this is a whole different world when it comes to tweaking this kind of gear. I do have the proper gear like the SENCORE SG 80 and HP Generators and Scopes Etc.
                            Look below at Adjustment 12:8. The Null adjustment. I have a Heathkit IM-28 VTVM that was rebuilt and has new Burned in tubes that I used for this...
                            12-30-2024, 03:18 PM
                          • shamsudeen
                            Epson M3170 Monochrome inkjet printer adjustment program tool
                            by shamsudeen
                            Epson M3170 Monochrome inkjet printer adjustment program tool.
                            Hi, i want to reset a epson reset program tool needed to reset the EPSON M3170 PRINTER's Maintenance box,
                            anyone having it, please share
                            Thank you
                            07-08-2025, 06:42 AM
                            Alexia thermostat is this a good idea for for controlling your air conditioning system feedback wanted
                            My wife is asking me about getting one because our electric bill was that it has ever been even more than last year at this time nothing has really changed since last year last month unless the electric company has done some fuel adjustment charges I have not done any investigation into yet but I might have to but there was a time back a few years ago that I use to set the temperature warm during the day when we were not home but when we got wooden floors in our house and you have to keep the humidity down to keep it from warping I just set to a temperature to 75*F to keep the humidity down but...
                            06-22-2025, 10:23 AM
                          • eurgenca
                            Philips TV 43pus7505 setting display option code, help please.
                            by eurgenca
                            Hello.
                            I am dealing with a Philips TV, 43pus7505 and is stuck on boot loop.
                            So I ordered a used CPU board, and now I have wired picture.
                            I think the problem lies in display option code. According to SM, the command for setting
                            display code is 062598 + MENU + 032 (032 is written on a label on back of a TV).
                            But as soon I press the menu button TV jumps in menu. Can someone please tell me what I am doing wrong,
                            or can I manually edit option code in SAM.​
                            10-07-2024, 02:09 AM
                          • Dobsuk
                            Pioneer turntable tone arm adjustment
                            by Dobsuk
                            Hi all. I have Pioneer PL-Z460 turntable but have some issue with the tone arm.
                            When the record finishes or stop it manually the arm does not go back all the way to the rest. It stops just short and then decends down onto the base. Is there an adjustment to make the arm go back a futher 0.5 cm?
                            There is only one screw at the base of the arm but it is for height adjustment:
                            Any advise please?...
                            08-18-2022, 12:41 PM
