Link to component 1UH, 11A, 20%
  • macca125
    • Sep 2022
    • 4
    Hi could anyone help me find this choke to buy from uk,photo attached. thanks
  • kasfamily
    • Aug 2014
    • 774
    • Russia
    Re: Link to component
    Burned down ?
      • 22109
      Re: Link to component 1UH, 11A, 20%
      https://uk.farnell.com/eaton/hcma070...-20/dp/2762622
      • macca125
        • Sep 2022
        • 4
        Thank you that's great
        • macca125
          • Sep 2022
          • 4
          Originally posted by kasfamily
          Burned down ?
          Yes exactly the same
          • greelidd
            K6604J Vivobook RTX 4070 BIOS Dump Request
            by greelidd
            Hi all! Tldr: need a bios dump (.bin format) for K6604J (rtx 4070 and i9-13980hx)
            Longer story: my vivobook stopped booting after i switched out the thermal paste. I think the BIOS got corrupted. Everything i tried didn’t work until finally i decided to buy a CH341A BIOS programmer and just send over the BIOS directly from another PC onto the BIOS chip. I connected fine and backed up the existing BIOS, but i can’t find a clean BIOS that’s a .bin format. And I tried using UEFI software to extract all the files from the ASUS BIOS .exe file and get to the .bin but it was a .302...
            09-01-2025, 06:14 PM
          • howardc64
            by howardc64
            07-24-2025, 05:17 PM
          • danielgerman681
            ENCONTRAR DATOS DMI EN EL CHIP BIOS IDEAPAD5 15ITL05 / FIND DMI DATA ON IDEAPAD5 15ITL05 BIOS CHIP
            by danielgerman681
            Hi, Im trying to find the area on the chip that contains all of my laptops information, but I havent found it. The laptop won't turn on anymore. I was updating the BIOS, and it was supposed to reboot itself, but it wouldnt turn back on. I ve tried every possible solution, every alternative on Lenovo forums, everywhere; I ve taken it to technicians, and no one has been able to fix it. I've already read the chip that contains the BIOS (Winbond 25Q128JSVQ) and searched for my laptops data, but they're nowhere to be found. I only find scribbles and lines of text indicating errors. Has anyone had a...
            08-27-2025, 01:17 PM
          • vettouch
            SHORT ON +3VLCD_CON (NO +3V) - HP COMPAQ G61
            by vettouch
            Please, see attached schematic and help me find solution to this HP COMPAQ G61, which has no display on both LCD and CRT. Thank you.
            Link to schematic - https://www.badcaps.net/forum/troubl...diagram-needed
            04-07-2025, 05:32 AM
          • flyhotstuff
            Alienware m15 r6 not charging.
            by flyhotstuff
            I bought this laptop sometime ago with an issue of it not detecting the battery but would work only with the charger, eventually, I found the problem was a missing resistor and replaced it and fixed the trace to it, it would detect the battery, but it would still not charge, it would detect the charger but fake charge. I recently moved so I did not have my regular microscope, I used a digital microscope I had to reflow/retouch the contacts of PUB1 which is an ISL95522A. I did not realise that I had bridged pins 16 and 17 and when connected to the charger, it blew the IC and the 10a (PRB13) resistor...
            03-19-2025, 11:41 AM
