Heat sink modding... thermal mass vs surface area?
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8701
    Well, my Gateway monitor seems to eat caps. So I was thinking there was some systemic issue going on here and what I'm thinking: the heatsink is blocking convection flow and thus roasts capacitors by radiation!
    Now what I wonder. This piece of aluminum heatsink is obviously blocking convective flow. I could add a fan but there are some other issues involved here. How about...drilling holes into the aluminum?
    The holes would add surface area and allow air to convectively flow through the heatsink which could reduce temperatures. However this would of course reduce the thermal mass of the heatsink which might cause other issues.
    Some mechanical engineering/fluid dynamics at work here... hmm! But a design defect here methinks.
    (And I'm out of 1000uF 25V low esr caps... sigh.)
    • Jul 2011
    • 6057
    Re: Heat sink modding... thermal mass vs surface area?
    I can not see how add a small cooling fan is going to all of that unless you just do not have the room to put a fan on the heat sink that a hole another story
    I have a boost converter that has a fairly good size heat sink and a very small cooling fan I found this to be a little odd that a designer would go this route because there is enough room to put a bigger cooling fan on it or another small cooling fan on the other end of the heat sink
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8701
      There is no room for a cooling fan really, at least without making the monitor fatter than it already is...
      • eccerr0r
        Solder Sloth
        • Nov 2012
        • 8701
        A picture of the crappy heatsink...
        There is a metal shield on both sides of the PCB with almost no gap.
        The dual diode MBR10100CT points straight downward. Seems the capacitors are basically radiated upon...
          • Jul 2011
          • 6057
          How tall is the heat sink is at least 40mm because you can get 40 mm fans there seems to be a space on the back of the heat sink in one corner I do not know if you can find a 30 mm fan or not but I would try it if the heat sink is extremely hot running it might help in the long run
          • eccerr0r
            Solder Sloth
            • Nov 2012
            • 8701
            around 25mm; maybe 30 mm or so with the board standoffs... the metal case just barely has space to fit standoffs and the board.
              • Jul 2011
              • 6057
              I hate manufacturers that do this crap I really do not think that they care if and how long something will last just get it out the door and it is not my problem anymore
              What about putting the fan in such a way that it blow on the heat sink ( and be mount on the case or on the heat sink where I have the text on the picture that you posted ) of the device just a thought I did this once and surprisingly enough it turned out better than I expected it to in fact it look like it was made that way but it took a lot of planing and a lot of patience to pull this off ( I have seen both extreme hot having enough cooling and to much cooling when not need and in both cases really are you kidding me )
              It might not matter to much if you can put it where it can not be seen easily it is just a thought
              I just bought a ZD-987 soldering iron/gun combination that I know is going to have a heating issue that I am going to have addresses because how this unit is setup and because of the amount of heat that is generated the switching power supply heat sink enclosure and it has two of them and you have the vacuum suction pump heat as well and this unit has the same very small cooling fan only on one side of it really are you kidding me you as a manufacturer of a device would do this crap
              I would be running them at the same time and for hours at a time failure is just around the corner
              • eccerr0r
                Solder Sloth
                • Nov 2012
                • 8701
                Blowing on the heatsink is one thing but the main problem is that the airflow is blocked by the heatsink itself... Can put a fan underneath but after it blows, the hot air has nowhere to go...
                ... hence if I drilled holes or cut slots into the heatsink, at least air will go through the heatsink and that's beside the advantage of having more surface area... though again loss of thermal mass/conductivity due to the holes...
                  • Jul 2011
                  • 6057
                  I really do not think that this would be a big issue I could be completely wrong
                  I would think that if you drilled very small holes through the heat sink where the fan is mounted I really do not think that you would loss that much thermal mass but you might gain a cooler heat sink in the long run
                  • eccerr0r
                    Solder Sloth
                    • Nov 2012
                    • 8701
                    but the idea is larger holes to let more air through instead of blocking... tough choice ...
                    In any case it would be best to have... no fan. Monitors usually don't have fans...
                      • 31158
                      can you get a long thin cap and mount it under the board?
                      • eccerr0r
                        Solder Sloth
                        • Nov 2012
                        • 8701
                        BTW the photo has a missing cap there that was removed... and there's another removed one right next to it just to the right and bottom above the heatsink. The two caps are both 470uF 25V and connected in parallel. I had a 1000uF there bent (see the picture in the other thread) to allow heat to escape, but as seen it died anyway.
                        So, need 1000uF (and there's less than 4mm clearance on the bottom side and almost 0 to the top)...
                          Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
                          The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
                          Securing a good thermal interface between...
                          10-07-2024, 04:35 AM
                          ALIENWARE Area-51 R2 i7-6900K Specification for Upgrade or Repair
                          This specification for the ALIENWARE Area-51 R2 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Area-51 R2 boardview and Area-51 R2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ALIENWARE...
                          09-12-2024, 03:28 PM
                          ALIENWARE Area-51 R4 i7-7800X Specification for Upgrade or Repair
                          This specification for the ALIENWARE Area-51 R4 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Area-51 R4 boardview and Area-51 R4 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ALIENWARE...
                          ALIENWARE Area-51 i7-5820K Specification for Upgrade or Repair
                          This specification for the ALIENWARE Area-51 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Area-51 boardview and Area-51 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download for ALIENWARE Area-51...
