Would anyone know what type of limiter this is? It is used on a surface element used in ranges. The contact i circled is supposed to be closed at room temperature but is stuck in the open position. I can close it with slight pressure but once open, it will remain open until manually closed. I tried cleaning the contact and still no help. Any ideas on how to fix it or does anyone know the part to replace it?
Range element thermal limiter
Re: Range element thermal limiter
The by metal strip is stretched and you will have to buy a new for it to work correctly do not try to fix it because it will not work correctly anymore and could be an issue
Just buy a new temperature control for this stove go to appliances repair service center with the model number and serial number just make sure that you know the size of the element there should be a part number on the element if not just measure the diameter of the element because there are different wattages on these elements and you need to use the right type temperature control for the the right wattage element
I hope this helps youLast edited by sam_sam_sam; 12-14-2021, 08:49 PM. -
A radiant surface heating element has two switches:
A limiter-thermostat that regulates the element max. temperature to protect the glass ceramic glass cooktop from overheating. It's the smaller switch and is calibrated by the small setscrew. Because of this, the switch comes with the whole heating element assembly. They can't really split that up.
Second is a high-high temperature safety switch which is the one giving you a hard time. The safety switch might latch, once tripped that's it, do not burn down the house?
The high-high limit switch can false trip if it's getting heat from poor contacts or the crimp connectors at the wires can also heat it up. Your switch contracts look not great, they seem to be touching only at the corner - which means high resistance and they will get hot when current flows through them, which can make the switch trip. It's supposed to get pressed by the white plunger poking it.
You can try to get the contacts to mate flat. These things are finicky and a constant hassle to monkey with. I don't have the patience.Comment
They are sold as an assembly- the heating element, limit switch, and ceramic base. Example:
https://www.amresupply.com/catalog/E...ce-632517-AD1C
https://www.appliancepartspros.com/g...ap4345739.htmlComment
Right. When i said element i meant the whole thing. Ok i was thinking i could find the limit switch on alieexpress or something like that but im not seeing anything. It looks like the limit switch would come off pretty easy. I was wanting to salvage the element and the base because it's brand new and the assembly didnt even work from the start when the stove was first purchased.They are sold as an assembly- the heating element, limit switch, and ceramic base. Example:
Just make sure that when you go to take off the control that hold the terminal ( with a wrench or an adjustable wrench ) goes into the element or you will break the ceramic housing the element terminals which breaks very easilyLast edited by sam_sam_sam; 12-16-2021, 08:39 AM.Comment
Post #1 shows a crack in the ceramic rim where the rod goes through, we don't know the history but OP says it's new so I would have gone after warranty. Somebody was rough on it.
At the center, the rod seems crimped in-place. Not sure how to remove the switch but I find these things are not repairable anyway.
Because it has a safety function and needs calibration for the limiter temperature, I think manufacturers just sell it as an entire assembly.Comment
Are these units the newer versions or the older version because the older version that I have seen was made a little differentPost #1 shows a crack in the ceramic rim where the rod goes through, we don't know the history but OP says it's new so I would have gone after warranty. Somebody was rough on it.
Many of these range heating elements are designed by E.G.O. who's getting them made in china. Haier US with GE, another mega-conglomerate appliance manufacturer as well.
Apparently the limit-thermostat keeps max to around 350°C and above 400°C trips the nuke meltdown switch.
Which part are you thinking is a newer design?Comment
It was replaced under warranty. I was just seeing if it was salvageable for a backup. Sounds like im better off throwing it in the dump.Post #1 shows a crack in the ceramic rim where the rod goes through, we don't know the history but OP says it's new so I would have gone after warranty. Somebody was rough on it.
by wnlewisI am trying to track down a replacement rocker switch for a Whirlpool RDE3340W electric range.
The rocker switch was made by McGill under their part number 0801-1059 and supplied to Whirlpool by FSP under their part number 686605. Whirlpool's original part number was 865745.
The switch is an On-Off-On type (SPDT) designed for use with either 115 VAC or 230 VAC. It is not lighted.
Are there any current switches that could be substituted for this switch?
Thanks -
TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...-
Channel: Common Parts Library - Datasheets
10-07-2024, 06:07 AM -
This specification for the Acer Switch Switch V 10 SW5-017P Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Switch V 10 SW5-017P boardview and Switch V 10 SW5-017P schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-06-2024, 05:30 AM
by wnlewisOK. I got the rocker switch figured out thanks to the good advice on this forum.
Now I need to figure out the correct wire to go to the switch from the broiler element and from the oven element.
This is a Whirlpool RDE3340 electric range.
The common wire on the switch appears to have a high temperature insulating material. I am guessing that both the wire to the broiler and the wire to the oven elements also need relatively high temperature insulation. What do I need to look for? The broiler is rated at about 2400 watts.
Where may I find parts... -
by Natob82Great to be here! I'm a newbie here trying to find a "micro", momentary push switch to repair a Sony "clamshell" video walkman. This micro switch has long since discontinued by Sony, however I hope there are third-party switches of the same size and functionality that I might be able to source to play the same role. The purpose of this switch is to tell the video walkman that the user has activated the mechanical tape eject button, turning that physical action into an electronic signal that tells the tape transport mechanism to open so one can load or eject a video tape. I...
- Loading...
