Re: Here is a good used source for 18650 batteries
All you would need is a couple of automotive type headlights as a load and use the fuel gauge on the battery pack this will tell you that the batteries can take a load it just would not tell you for how long it would run the load unless you could stand there for a few minutes with the load hooked to the battery pack but it might let you know if you had bad battery cells or not
This would be better than not testing it at all
If you can test it for several minutes and it does not dim down much and the price is right I would take my chances on them
Damn. It's an off-brand battery pack so who knows what's in it, was meant to be a clone of a name brand tool of some sort.
But I got an OK from the shopkeeper to bring in a contraption to test it. A multimeter isn't enough IMHO (BTW, the LED fuel gauge reads "full"), I need to load test. now I need to design and build a test circuit of some sort that I can carry into the shop...and hope it doesn't get sold to someone else...
I have the same problem I have a collection of bad cells that I need to figure out what to do with them but I going to wait until I have finished building some of these battery packs before I deal with this issue
Battery Hookup had some brand new batteries for sale about a month ago that had never been used but there was a catch that they were being prepared for welding them together however there laser machine that would be used malfunction so company sold batteries surplus but use some type of glue on the negative side of the battery that need to be cleaned off to be able to used them which took some time to do but I have tested some of them and they are 3 amp hour batteries from Panasonic and these batteries were $1.00 each and came in a box of 30 but they did not last long for sale I bought 3 boxes of them I still have to clean only one more box of them but this set of them have some type of soft glue that get everything glue-e and I have not figured out how to clean them with out getting the glue everywhere
And the reason for why these were sold for a dollar each
You need to clean the glue off and
You need to put heat shrink tubing on them because they come natural with only the metal housing showing
But Battery Hookup supply you with the heat shrink tubing already cut to the correct size and the fish paper for the positive side of the battery terminal
You have to test them for current capability to make sure that all battery cells are testing good before being used
I do not mind having to process batteries in this condition yes it some work to do this before you can test them and before you can use them but they are brand new and have not been welded on which is a plus for me
These batteries are going to be used in a battery housing that I bought on eBay that is for 12 volts at 18 amp hour which can hold 48 batteries in it ( 3s@16p ) and still have enough room for the BMS protection board in the case I just need to make sure that the BMS protection board that I have with fit into the housing
Unless I want to pay $75.00 for a BMS balancing protection board that has Bluetooth capability for being able to watch the battery on charge and being discharging while being in use I am thinking about buying it but have not completely decided on this yet
https://www.ebay.com/itm/23386178568...0AAOSwrDRhXXSO
Which if my calculations are correct this would be a 48 amp hour battery pack wowLast edited by sam_sam_sam; 12-26-2021, 04:13 AM.
mmm... need to start getting/building packs that approach to the kilowatt-hour mark...
Them again, starting to collect too many bad cells too, in laptops I still use... ugh.
Here is some batteries that I bought a couple of years ago and they were a disappointment because they are not 3.3 amp hours like it says on them but they do not heat up but when I first bought them they never had much higher amp hours rating that they do now
I will give them to someone who is interested in them just pay for the shipping I think I have 3 or boxes of them but there is only 6 to a box if remember correctly
Just PM if you are interested in them I do not want them to go to waste if someone else can use them the outside cover does not come with them however but they will be individual wrapped to not short out and I will test them to make sure that you do not get any that are DOA
Originally posted by sam_sam_sam View PostHere is a very very good deal I have yet to see a battery below 2.50 volts and few I have tested I got at 2200 milliamperes hours
I had ordered 30 of them
https://batteryhookup.com/products/3...cells-with-pcb
I just ordered 40 more
Unfortunately they are out of stock on this item and I have not seen it return yet
The results are looking at the graph and where the voltage is at 3 volts is where I getting this value from not the total amount of milliamperes hours that when it reaches 2.8 volts as the SkyRc IMAX b6 tester shuts off at which is when it is at 100 milliamperesLast edited by sam_sam_sam; 12-25-2021, 02:01 PM.
This is sort of a surplus store, so can't predict what they have. I also don't remember the brand name of the pack.
The theory is that they're new but possibly a return, but that could also mean it was defective... At 24V it is a weird number, at 6S3P it would get close to 24V 6Ah with 2Ah cells, else it would be 6S2P with "3Ah" cells. I think it's more likely 6S3P but it's possible it has something other than 18650s in it. They were definitely "dense" as in heavy for its size - assuming the package isn't lying and they put lead acid cells in them, but there's no way to get 24V of lead acid cells in that small of a package..
TBH I would not pay $1 for a used cell or even $0.50/cell for a bad pack (e.g. pay $4 for a dead 8-cell laptop pack?), but the chance these are good condition cells for a power tool made me think...alas it's still a gamble.
Not sure if I can sneak a multimeter in to test, nevermind open, unfortunately.Last edited by eccerr0r; 12-25-2021, 02:56 AM.
If unknown use I personally would not pay more than a dollar per cell but I would at least measure the voltage of the pack to make sure that it does not have electrical issues
One note if there is no voltage on the output terminals of the battery pack it could be that the BMS protection board has locked it out and at this point I would not pay more than $0.50 per cell because you would be taking more of a change that there might be bad battery cells
The only way that I would consider paying more than a $1.00 per cell but a maximum of $2.00 per cell is if I was allowed to open the battery packs and check the the battery voltage but make sure that the voltage does not vary more than 0.500 volts because it has been my experience that if varying more than this then there could be issues with some battery cells and what brand of batteries that were used and milliamperes hour rating that they have all play a part in how much I am willing to pay for used battery packs
One note about 6 amp hour battery pack it could 2p or 3p if it is 3p I would not pay more than $1.25 per battery cell if it 2p then I would go to $2.00 per cell maybe a little bit more if the battery voltage per cell does not vary more than 0.250 per cell and you do not see any signs of battery cell leakage what so ever but my maximum would be $2.50 per cell
Do you know what brand name of the battery packs are because if you do I might be able to to tell you what brand of batteries that it might have in them
If you plan on using the BMS balancing protection board I would highly recommend that you buy the battery charger for the pack
One note if the brand names of the battery packs are RYOBI or Milwaukee or Kobalt I can tell you what brand name batteries are in them and they are a safe bet as long as you have have voltage on the battery pack but I still would want to open them up to see the condition of the battery cells
I hope this helps youLast edited by sam_sam_sam; 12-25-2021, 02:58 AM.
hmm... wonder how much I should pay for two 24V 6Ah (12Ah total) Li-ion battery packs for some unknown tool, supposedly new, purchase locally, but I can't refund them. Plan would be to harvest cells only but maybe I could use the BMS if it has one, or perhaps the whole pack. Wonder if it's worth the risk and how much I should pay max to take the risk...
Update on these battery packs
Pack number 2 the battery voltage was a lot better 32 volts instead of 28 volts on the first battery pack tested and voltages not really near each other
Radom checked on a few cells and voltages was around 4.0something which is a lot better than the first pack
So I am charging this battery pack up with the build in BMS protection board there is no current limiting on this battery pack either because it is done on the charger end of it
To add to the post above
The interesting thing about this version of this battery is that not all of these batteries have the same charging and discharging curves I have to wonder if there is some kind of quality control issue when these batteries were made
Because most of the time when you have a lot of batteries that are the same version they all have basically the same charging and discharging curves but not this series so I am a little confused about what I have been seeing with this series of batteriesLast edited by sam_sam_sam; 11-28-2021, 02:20 AM.
Here is an update on this battery pack
The individual battery cells so far are testing at around 2100 to 2200 milliamperes hours = 3.00 volts @ 500 milliamperes working dropout voltage and 2400 milliamperes hours when battery tester shut off and battery is rated at 2600 milliamperes hours
Which means that the useable battery life is 90% when battery voltage reaches 3 volts under load around 80% to 85% if you use 3 volts at 500 milliamperes maximum dropout current
The one thing that I noticed about these batteries is that charging curve voltage is not very impressive it is steeper than what I expected to see I prefer to see less steep climb in voltage until it reaches around 3.8 and then level off and slowly climb until it reaches 4.2 volts
Now the discharge curve is a little bit better but it is a little steeper drop when battery voltage is around 3.5 volts is when it becomes more steeper than what I expected it to be
I will use these batteries in another project because of the charging curve and discharge curve resultsLast edited by sam_sam_sam; 11-26-2021, 10:32 PM.
Here is another item from Battery Hookup that is also interesting item
https://batteryhookup.com/products/8...-cells-ibh9100
Now this one is hit and miss with weather or not you get good batteries or not I bought 6 battery packs and two had bad batteries in them but I can reuse the battery pack case for a project so I am not to worry about it not being good
But if you do get good ones they will be at or above 50% of charge on build in fuel gauge
One note you do have to use plastic pry tool to open the battery pack enclosure it does take some work to pry it apart but the enclosure can be reused for 8 (18650 battery cells )
One more note I am not sure that you can use the BMS protection board or not because I have not figure this out yetLast edited by sam_sam_sam; 11-20-2021, 07:00 PM.
I bought a few of these battery packs and they are very interesting for $29.00 for 24 batteries and the BMS protection board which they claim that also works but I have not tested it yet but I will let you know if it works correctly or not
This was also bought from Battery Hookup but unfortunately they are out of stock already again for the second time since they started offering this item
I am going to use this for a LED yard light that the switching power supply took a shit and can not be repaired because it has leaking capacitors and it is incapsulated with black hard plastic I guess that what this stuff is
This operating voltage is 32 volts and this battery pack has this voltage as well I just have to find a weather tight enclosure that will fit this battery pack/BMS board commination I already have the solar panels that I bought a while back that was also surplus but at the time the project that I had in mind had technical issues that I could not overcome at the time so they have just been sitting here collecting dust until now that I have found a battery pack that will work the LED yard light that also has issues and just repurpose both items to be used in another way
I am going to be testing this battery pack in 12 volt sections and one 8.4 volt section just to be sure that the milliamperes hours rating that they claim to be
I have found that the medical grade battery packs are most of the time are good quality devices and are easily used for projects
I will post some pictures of this project when I have completed it so you can see what I came up withLast edited by sam_sam_sam; 11-20-2021, 08:04 AM.
Originally posted by eccerr0r View PostStill need to write code...sigh. I think should do this, would open a lot more avenues to implement the actual circuit - the design I drew out was an H-bridge direct drive but with the code I could dabble with a safer, transformer design ...
Originally posted by eccerr0r View PostNothing's happening mainly because batteries are too expensive and I'm too lazy to get a circuit board etched since I've been having one heck of a time trying to get it to one layer...so I can self etch.
Also though most of the components on the board I have (salvaged and parts collection), there are a couple I don't, plus I need to write the microcontroller code. No board, no wanty to write code. Since I don't have code, no wanty to make board. Ugh. Vicious cycle. Really should put it on a solderless breadboard to see what it does...
Originally posted by eccerr0r View PostThought I mentioned it... Homemade Grid tie "power wall"... down to conponents. more of a design challenge for a complete power arbitrage system. Use cheap power (solar, off peak grid electricity) to offset or overtake peak price power.
Expense of parts is one problem but with a surplus of random parts in my parts bin, I must use these when I can. Batteries are not in my surplus however.
Yes, planning to implement anti-islanding... and have an override!
Originally posted by stj View Posthonda used nimh until 2010
