BGA 153 programming
  • nfrancis63
    • Feb 2019
    BGA 153 programming
    Hi
    Looking for someone in the essex, uk area to programme EMMC chips for me. They are bga153 nand chips and I have the programme which needs to go on them.
  • ugamazing
    Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
    by ugamazing
    I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
    08-31-2022, 07:34 AM
  • artesano1969
    Reading and Programming ASUS iRog chips - EPF035 / EPF 036
    by artesano1969
    Well, I think this is the first time I'm sharing something here, I hope it will help anyone that, like me, is trying to repair one of those damm ASUS motherboards filled with iRog chips. I've written a manual following my experience and findings on fixing a dead ASUS Rampage IV Extreme (R4E).
    The ZIP file contains the guide and (almost) all the software I've used in the project. But I think it's worthy because it took me a lot of time to find out a cheap way to work with these chips from Explore with a bare CH341A programmer, and the original EP Console program is really hard to find....
    05-19-2024, 09:50 AM
  • feherhollo
    WSON8 NEW Bios Chips READ, ERROR, ETC.
    by feherhollo
    I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
    I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
    For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
    11-26-2023, 09:33 AM
  • H34TO
    ITE IT8390 (IT8390E-256) programmer "ITE Download Board 4" user manual + firmware, flashing ITE ECs on the cheap
    by H34TO
    Recently I've gotten into EC flashing due to my broken laptop(s) and started frantically searching methods for flashing the IT5571E-128 chip on the cheap(due to me beaing a student and not having a job) and noticed that ITE newer chips can be flashed via ISP (In-System Programming) either via SMBus or the KBC (EPP - Enhanced Parallel Port) interface. While these can be achieved with programmers like SVOD4/3 or the RT809H/F those options are WAYYY out of my budget so I was horrified. But recently I stumbled uppon some programmers on aliexpress that claim they can program a variety of ITE chips...
    06-17-2025, 07:17 AM
  • Prott
    [RoG Ally] Fault in one of the onboard RAM chips. Any way to diagnose which?
    by Prott
    Hello dear badcappers!
    The title pretty much says it all - do you, please, know if there's any way to troubleshoot which of the integrated RAM chips (LPDDR5X in this case) is faulty?
    Backstory:
    After replacing the 4 onboard (soldered) memory chips on a RoG Ally (4x4 GB to 4x8 GB) it got stuck on the RoG logo. I assume one of the chips is either not soldered properly or faulty. However after reflowing and replacing bunch of them I am still stuck at the same place.
    If there is a way to narrow down which memory module is faulty it would make my life much...
    06-03-2024, 12:05 PM
