Originally posted by televizora
View Post
Question on AC grounding - found an old device that has me confused
Re: Question on AC grounding - found an old device that has me confused
Only the ground terminal of an outlet can be connected to the chassis of a device, if it is not ClassII - Double insulated. This is wrong. Perhaps it relies on a plug with a 3rd dummy pin, so you cant reverse the plug. But it's still wrong. Replacing the plug or improperly wired outlet could lead to you being electrocuted. If these were our unpolarized sockets, there would be dead people.Last edited by televizora; 02-14-2021, 09:43 AM.
2010??
Originally posted by stj View Postdoes it have any datecodes on it?
And as I was looking at the circuit board, all I saw was just analog components and thought ... how in the heck could they build something like this as small as it is without any ICs in it then when I took the bottom shield cover off of it, I saw the IC which I'm assuming is what sets up the channel injection frequency? There are definitely no crystals anywhere and it's lead-free which means it's probably newer than the '80s.
Originally posted by Per Hansson View PostI can not imagine this would have ever been up to code in any country in the world at any point in time.
EDIT: If you remove the heatshrink tubing from the wire that goes to the chassis is there at least a resistor in there?
If it is then it will only give you some mild tingles when you touch it if it's connected with "wrong polarity"
If not: then you will die if you touch it with "wrong polarity"
Originally posted by EasyGoing1 View PostApparently sometime between the early 80's and probably the late 90's it was not forbidden! Just no idea when they finally deemed the practice a big NO NO.
If not: then you will die if you touch it with "wrong polarity"Last edited by Per Hansson; 02-14-2021, 08:02 AM.
Originally posted by Per Hansson View PostIt is completely forbidden to do this with a metal enclosure that the user can come in contact with!
Here's a picture of the front of it.... but no relevant information there either.
Originally posted by stj View Postnothing unusual back in the old days.
they did the same shit with radio's and tv's in the u.s.
You could never touch the metal parts which had a 50% chance of being at mains potential.
Today in modern designs this is called double insulated, it is signified with a mark with two squares inside each other.
What these all have in common is that they are non-conductive, i.e. wood or plastic enclosures.
Originally posted by stj View Postto answer the first question,
it's a modulator, you put it between your antenna and tv set.
then you feed composite video and line level audio into it from a vcr, camera or computer and it mixes it in with the other rf channels.
then you feed composite video and line level audio into it from a vcr, camera or computer and it mixes it in with the other rf channels.Last edited by stj; 02-14-2021, 07:22 AM.
That's a death trap: if you reverse the AC plug the chassis will be live.
Sure in the US & UK the plug it is polarized, but it is very common to have the live and neutral reversed in the outlet.
The only thing I can think is that this is not original:
If it is the company should be brought to justice for it, this is just crazy!
So I needed to find something that I don't use so I could cut the power cord off of it and use it in a project.
So I found this ... Radio Shack looking device that apparently takes an external TV antenna as an input as well as RCA connections as inputs Then on the front you can choose to have it send out to the TV on channel 3 or 4 - though I have no idea what it does with the two different inputs...
But anyway, I figured before I cut the cord and toss the device in the trash, I should bust it open and see if there's anything useful inside to add to the spare parts bins... and when I pulled the cover, I saw something that seemed really odd to me.
It has a two-wire electrical cord on it, yet one of the wires, it connects to the metal portion of the chassis.
Now I'm aware that the third lead on an electrical outlet is earth ground, and that it's common to use that third prong in an appliance so that if somehow the unit malfunctions and one of the other two leads gets loose or something, that it will divert current to earth ground so that if a person touches it, it won't prefer channeling current through the person.
But to connect the return line from an AC outlet to the chassis ... isn't that potentially dangerous? I mean if someone was barefoot, standing on wet carpet and just picked up the unit, couldn't it electrocute them?
Here are some pics.
Tags: None
