RAB Lighting 30 and 48 White LED 9-12VDC Blinding Light Bars—> Very nice light bar
    • Jul 2011
    • 6070
    I bought these LED light bars from Electronic Goldmine surplus store online
    These light bars are the nicest LED light bars I have ever seen in there online store
    I read the description of these light bars and said yeah right there bright at 9 volts
    Let just see if this is the case or not and just how bright is bright because I bought some of there light bars that they said were very bright and were ok but I would not say they were as bright as they claim
    But I thought I would give these a try only because they had both light bars on sale as a bundle both of them together for Ground Hog Day Sale for $6.95 well worth the price for a test of just how bright they are for this price
    Disclaimer these are not on sale now but even with them at the price they are at still well worth the cost of them
    The voltage range is 9 to 12 volts you only have to use 9 volts and it very very bright light bar
    I thought I would share this find with all of you the website links are below
    https://www.goldmine-elec-products.c...?number=G24723
    https://www.goldmine-elec-products.c...?number=G24725
    To me the cost of them is very reasonable for how bright they are I would recommend a heat sink on these light bars even with the voltage at 9 volts because in a very short period of time the temperature of the light bars do get warm gradually that is why I would recommend using a heat sink if you are going to run them for hours and hours of use or 24 hours a day
    I am going to use them for my work table in my shed am going to some more of each one but because I am a cheap a** I going to wait until they have a sale on them again and then buy some
    But what I going to do is two of them in series and run them on a laptop computer switching power supply to run them I have a heat sink from a Hyperthrem plasma torch power supply which has a very nice heat sink
    I going to cut it down to size and put a computer fan on it to cool it
    • Jul 2011
    • 6070
    Re: RAB Lighting 30 and 48 White LED 9-12VDC Blinding Light Bars—> Very nice light ba
    Update until Monday night ( 2-15-21) at 11:59 pm SALE $7.50
      • Jul 2011
      • 6070
      These LEDs light bars are on sale again until Friday @ midnight
      https://www.goldmine-elec-products.c...number=G24723A
      I ordered one more set of them you are limited to one set or you will pay $500.00 for each one
      • redwire
        • 3912
        Thanks for the heads up.
        I saw it was $7.95 and just went up? One 4-pack RAB Lighting 30 G24723A strips for $9.95 (Limit 1 Per Order). You can only order one pack.
        It's been a long time since I ordered Chaney Electronics kits but the prices seem to be mostly too high.
        Goldmine minimum order $10 or $50 international. Minimum shipping & handling of $7.65 up to 1 lb. in USA. I'd have to order $40 of other stuff plus exchange, shipping etc. so not worth it then for four strips.
        I was looking at getting some LED strips to make a photography light box:
        EEVblog #1372 - DIY PCB Photography Light Box
        EEVblog #1373 - DIY PCB Photography LED Light Box - Part 2
        BigClive - How I get my crisp macro shots with tupper-cam but flexible strips used.
        I need decent CRI and the LED strips off eBay are hit or miss, usually low quality blueish white or yellow white. I just got Cree LED's CRI 95 in 2835 package to try out.
          • Jul 2011
          • 6070
          The ones that he shows in his post are easily found at Home Depot they are used in conversations from the old fashion yard lights you would just take out the transformer and circuit board if had one replace it with type of
            Lithonia Lighting versus Light of America Compact Fluorescent product quality
            by sam_sam_sam
            I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
            I also have back when Light of America had these light bulbs available for yard lights
            The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
            While the Lithonia lighting fixture has all most certain bulb failure
            So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
            I have only had this light fixture for not more than a year if it...
            07-02-2023, 03:45 PM
          • BlueNitesFire
            I need Lenovo yoga 6 13ARE05 bios- broken screen and no bright light on keyboard
            by BlueNitesFire
            So I couldn't remember my bios password and since it was broken screen, I used to connected to the TV via Type C to HDMI. So I decided to remove the Bios chip and reprogram the Bios chip with ch314a.. when I try to solder Bios on the laptop, one of the Bios leg broke off.. I bought a new blank Bios chip so I can programmed by flashing on the bios.
            03-08-2025, 03:49 PM
          • howardc64
            by howardc64
            Problem
            08-04-2024, 10:36 PM
          • howardc64
            UN55NU7100F failed edge lit LED bar, poor quality replacement LED bar AND bulging cap on PSU
            by howardc64
            Just typical LED bar failure repair but discovered a couple of things worthy of posting
            PSU had a bulging cap (470uF 25V). Likely AC/DC bridge rectifier filter. Have seen a ton of 470uF bridge rectifier filter failures on a bunch of difference devices (not just TVs) Stock up on 470uF 25v 35v
            2nd thing worth of note is after all the work to replace edge lit LEDs. Discovered 2 LEDs with phosphor coating differnce produing slightly differnet color temp. Result on edge lit TV = dark veritical band Can't detect when testing the LED bar along...
            10-13-2025, 05:56 PM
            LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
            This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-07-2024, 03:40 AM
