Oscilliscopes
  • EasyGoing1
    Shock Therapist
    • Sep 2016
    • 977
    Oscilliscopes
    If you had $350 to spend on a scope, which one would you get?
    And does anyone know of a sub $50 multimeter that can read down to the 10s or 100's of µA ?
    sigpic
    • 31044
    Re: Oscilliscopes
    scope-wise, Rigol or Siglent.
      • Jul 2011
      • 6040
      Re: Oscilliscopes
      You might have to spend a little bit more money than this to find a good quality one for the money
      • petehall347
        • Jan 2015
        • 4427
        • United Kingdom
        Re: Oscilliscopes
        tektronix or hitachi
          • 31044
          Re: Oscilliscopes
          you dont get tek or hitachi for that price unless they are 20years old.
          that money can buy a brand new 4 channel scope from rigol or siglent
            • Jul 2011
            • 6040
            Re: Oscilliscopes
            Here is one model that might what you are looking for not this model number though
            MASTECH MS8239C
            I have use a Mastech meter before at a job over 10 years ago and back then there meters were pretty good back then I have no idea what kind of quality they have now
            Or this model that the picture is below I have used this meter for a while I have not used the UA setting before but have used the milliamperes scale and the amp scale and have no complaints about the use of it
            It does have Bluetooth capability and does work pretty good with the Apple application it works fairly good easy to use but it is very basic in design
            If I remember correctly it was under $50.00 on eBay
            I hope this helps you
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16956
              Re: Oscilliscopes
              My Sencore SC3100 I bought new for a lot more than $350 has been a great one. They can be had now in your price range. 100MHz, dual channel. Built in DMM and frequency counter.
              <--- Badcaps.net Founder
              Badcaps.net Services:
              Motherboard Repair Services
              http://folding.stanford.edu/
              Team : 49813
              Join in!!
              Team Stats
              • PeteS in CA
                • Aug 2005
                • 3581
                • USA, Unsure of Planet
                Re: Oscilliscopes
                Extech's EX205T, http://www.extech.com/products/EX205T , lists for $44.
                Extech's MS240 20MHz, 2 channel digital oscilloscope (including probes and accessories), http://www.extech.com/products/MS420 , is $950. Being battery powered, it can be used to probe the primary side of a PSU. It also has a built-in DMM function.
                http://www.extech.com/products/MS6060 - 60MHz, $999
                PeteS in CA
                • EasyGoing1
                  Shock Therapist
                  • Sep 2016
                  • 977
                  Re: Oscilliscopes
                  I own a Fluke 117 and had I known at the time that micro amps would be important, I would have chosen better. Just feels wrong to spend that kinda money again just to get microamps when I've got a good meter.
                  I dunno ... I'm sure ill end up biting the bullet and springing for the right one.
                  sigpic
                  • EasyGoing1
                    Shock Therapist
                    • Sep 2016
                    • 977
                    Re: Oscilliscopes
                    So Amazon has two Rigol's around $350 ... this one is a 2 channel 200Mhz and this one is a 4 Channel at 50 Mhz
                    THEN, I saw this sexy lil thing ... but it's a buck and a quarter over budget ... yet it might be worth it.... But just look at it ... it exudes class and style and it says ... "I'm gonna be here for a long time doing a damn good job"!
                    sigpic
                    • EasyGoing1
                      Shock Therapist
                      • Sep 2016
                      • 977
                      Re: Oscilliscopes
                      So as I was looking at the Siglent page, I noticed a timer counting down at the upper right. When I clicked on the scope, the price was $474 ... but that timer was telling me that I had just 10 minutes to take advantage of some deal I stumbled on and the scope was at $424 ... so figured since I'm Amazon Prime if for some reason I don't like it, they will take it back no questions asked.
                      I went ahead and got it... should be here Monday.
                      sigpic
                      • EasyGoing1
                        Shock Therapist
                        • Sep 2016
                        • 977
                        Re: Oscilliscopes
                        Here is the scope I ended up buying. It should be here Monday. It was a little over budget, but it seems highly functional with some cool technology in it including a web interface that can be accessed from anywhere. :-)
                        sigpic
                          • 31044
                          Re: Oscilliscopes
                          a very good scope.
                          i think you can even hack the software to upgrade it to 200MHz.
                          there is a thread at eevblog about that.
                          same for the rigol btw, you buy the 50MHz and unlock it to 100MHz.
                          but the siglent is better - and can go to 200MHz
                            • 31044
                            Re: Oscilliscopes
                            https://www.eevblog.com/forum/testge...-step-by-step/
                            • Topcat
                              The Boss Stooge
                              • Oct 2003
                              • 16956
                              Re: Oscilliscopes
                              Very nice!
                              I just haven't been able to let go of my old CRT scope....
                              Team : 49813
                              Join in!!
                              Team Stats
                                • 31044
                                Re: Oscilliscopes
                                what i want for my collection is a hybrid design from HP.
                                just before they went to lcd they produced a range of traditional looking scopes that where actually digital with a mini CGA? (24KHz) monitor in them!!!
                                the top model was colour!
                                unfortunatly every time one is on ebay some scumbag collectors who will probably never use it bid them up to stupid prices!!
                                same thing happens with HP bench meters - i know for a fact some of the buyers have 5+ of the same model just stacked for display/bragging rights!
                                • EasyGoing1
                                  Shock Therapist
                                  • Sep 2016
                                  • 977
                                  Re: Oscilliscopes
                                  a very good scope.
                                  So it's already capable of 200Mhz, just have to hack it and enable it? ... sweet!
                                  sigpic
                                  • EasyGoing1
                                    Shock Therapist
                                    • Sep 2016
                                    • 977
                                    Re: Oscilliscopes
                                    But ... who are they bragging to? LOL
                                    Maybe you could find a broken one for a good price and fix it?
                                    sigpic
                                    • EasyGoing1
                                      Shock Therapist
                                      • Sep 2016
                                      • 977
                                      Re: Oscilliscopes
                                      Originally posted by Topcat
                                      Very nice!
                                      If you got table space to throw away ... then more power to you!
                                      I'm kinda the same way though ... if it works, seems like a waste to buy another one. That's why my last laptop was almost 10 years old before I bought a new one after it finally gave up the ghost.
                                      I even tried to save the old one... it just kept shutting down for no reason and after a lot of troubleshooting, I figured there must be microfractures in the lead-free solder on the mainboard somewhere so I even stuck the mainboard in the oven for 10 minutes to re-flow the solder. That actually worked for about a week or so till it started shutting down again... each time the re-flow only worked for a few days ... then a few hours ... then I finally just called the time of death and stopped CPR and bought a new one lol.
                                      sigpic
                                        • 31044
                                        Re: Oscilliscopes
                                        they are already broken on ebay.
                                        they are bragging to each other = posting pictures of their "collection" on eevblog!
                                        • 6BW6
                                          Siglent SDS2352X-E scope?
                                          by 6BW6
                                          Does any one have any opinions on the Siglent SDS2352X-E scope, are they reliable? I almost got the 300Mhz 2Ch Rigol, it seems Siglent has the edge.
                                          Dave
                                          07-10-2020, 11:40 AM
                                        • EasyGoing1
                                          Reading input and output of bridge rectifier on the same scope?
                                          by EasyGoing1
                                          I have a 40 volt AC transformer that I put a bridge rectifier on, and I wanted to see the input signal and the output signal on the same screen on my scope, so I set one channel up with the test lead on one side of the input and the ground lead on the other side of the input, then I used another channel on the scope and clipped the test lead on the positive side of the output then the ground on the negative side of the output.
                                          When I connected the transformer to power, the wire that was connected between the ground lead on the second channel and the negative side of the bridge rectifier...
                                          06-26-2022, 12:52 AM
                                        • Duranitron
                                          [B]Lenovo Ideapad 100S-14IBR EEPROM VCC shorted to ground[/B]
                                          by Duranitron
                                          need help guys.. Bios ic UX3 - 25Q64FWSIG no 1.8 volts
                                          shorted 1.8ALW volts to ground. eeprom is ok
                                          Findings : i disconnect the vcc from the circuit using jumper 1505 and test the output of the 2Z-3F F0V ic it produces 1.8v so i injected a 1.8v in the vcc of the eeprom and somehow the processor is heating up and it draws 2.090 amps .
                                          my question is how much current does this ic can produce at normal level. does the 1.8vALW powered the processor.
                                          am i dealing with a shorted processor?...
                                          08-24-2022, 06:29 PM
                                          Component tester which one is worth the money from it capability to test and identify
                                          by sam_sam_sam
                                          I am thinking of buying a component tester but I want to get the most out of the device for the money that I am going to spend
                                          Any idea but I would prefer actual use of the device it good points and it short comings be completely truthful about the review of the device
                                          There are so many versions of this type of device and I do not have enough information to make a good decision at this point
                                          When I bought my battery testing machine I had some information to go by because of electrical experience with auto electrical experience in this field job wise (...
                                          06-30-2022, 08:23 PM
                                        • mariukonie
                                          Induction hob PCB VESTEL 20fr25 from cooker Rangemaster propl60eibl help needed.
                                          by mariukonie
                                          Hi. Could anyone with knowledge advise if this pcb in photos can be repaired? I'm willing to spend time and money on it to gain experience however I searched net for schematics and couldn't find so it's impossible to know what are some of burnt components. I can't find any second hand replacement board and new one is out of my budget and it exceeds value of cooker. I'm new to this forum but have had few successful pcb repairs of tv's and cooker pcbs and also made few working circuits for fun. Any help appreciated. Regards....
                                          08-23-2023, 08:19 AM
