Need pointers to knowledge sources for electromagnetic application
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8658
    Re: Need pointers to knowledge sources for electromagnetic application
    You need thicker/less resistive/paralleled wire so you can drive more current using lower voltage (hint: those bldc motors have thick windings for a reason!), or possibly a core with higher permeability; though I suspect eddy currents would be an issue when spinning very fast - so electrical steel or better?
    • EasyGoing1
      Shock Therapist
      • Sep 2016
      • 977
      I wonder if these would do the trick...
      sigpic
      • EasyGoing1
        Shock Therapist
        • Sep 2016
        • 977
        So I bought some 16 gauge transformer wire and made another coil, but it didn't work much better than the first one, so I ended up buying these coils on wish.com ...
        I wired them up like this:
        Here is the first spin I got ...
        it's a little rough so obviously, I'm going to have to play with voltage levels and timing, but it looks like I'm on the right track.
        sigpic
