I have some old desktop computers that I got that been in storage for about 3 years
    • Jul 2011
    • 6070
    I have some old desktop computers that all seem to have the same exact problem
    They all have at least one blown open capacitor on the mother board
    One of does not have any blown open capacitors
    But they all have the same problem in that it does not recognize the hard drive or the CD rom drive and the computer seems to be drawing a lot more current than I think it should
    All the cmos batteries are dead and have gone back to default data and time
    You can get into bio setup on all of them
    What could be the problem with them and is it easy to fix
    How would I go about troubleshooting this problem
    The switching power supply has been recapped and all the voltages look good
    except the 12 volt rail is a little low at 11.58 volts
  • R_J
    • Jun 2012
    • 9621
    Re: I have some old desktop computers that I got that been in storage for about 3 yea
    Not enough information. What type of drives sata, ide, other? do the hard drives spin up? do they show up in the bios?
      • Jul 2011
      • 6070
      No they do not show up in bios
      The hard drive feel like they spin up but not as fast as I use to the hard drive LED light does not light unless you put the jumper on cable select then it light but stay on the hole time
      The cd rom drive spins but does not spin up fast the green LED light is flashing like normal
      They are ide drives
      • R_J
        • Jun 2012
        • 9621
        What is the voltage on the 4 pin molex plug going to the drives? it should be +5 and +12 volts
          • Jul 2011
          • 6070
          5.1something volts
          11.58 volts
          • R_J
            • Jun 2012
            • 9621
            The voltage going to the drives seems to be ok. check that the ide cable is connected properly, pin 1 on the board to pin 1 on the drive. If the cable is not keyed it can connected backwards. Pin one should be marked by a line on the cable
            Are you sure the drives are working? Try loading bios defaults, Ususlly the drives should show up in the bios, even if they have issues
              • Jul 2011
              • 6070
              The cable is keyed and it has a red line
              No I am not sure that the hard drive work but it should still show up in bios
              Unless the hard drive controller is not working correctly at all
              I did that a few times and did not work I also did some other ways that did not worked either
              Usually the drives should show up in the bios, even if they have issues
              The cd rom drive dose not even show up either
              Which is making think that there is something wrong with the IDE controller
              But the question is what is wrong with it and where is it on the mother board
              • petehall347
                • Jan 2015
                • 4448
                did you set the jumpers in the drives ?
                  • Jul 2011
                  • 6070
                  Yes and did not make a difference
                  Or no jumper at all or cable select did not make any difference
                  On both hard drive and cd rom drive
                  • R_J
                    • Jun 2012
                    • 9621
                    What is the motherboard make/model and who is the bios maker? This will likely help in resolving the issue.
                      • Jul 2011
                      • 6070
                      I will post some pictures tomorrow
                      • R_J
                        • Jun 2012
                        • 9621
                        Make sure to include the motherboard number in case it's not in a picture
                          • Jul 2011
                          • 6070
                          Update on this computer mother board setup (model number is a IBM 8183 WGX )
                          The C-MOS battery was dead was the number one problem ( I did not think that you have to have a good battery to able to recognize hard drive in either IDE or SATA drives CD or Hard Drive )
                          The bios setup is not straightforward like what I am use to ( I am use to the bios recognizing the hard drive )
                          I had to use a sata hard and IDE cd rom drive for it to install Windows XP correctly
                          ( or all of my IDE hard drive have some kind of issue that I have not figured out what this issue is
                          because I have a e-machine mother board that does not have a problem recognizing the IDE hard drives so what up with this crap )
                          To find the driver for this mother board is the biggest pain the ass IBM does not have them on there website l found them on there forum website and to unpack another pain in the ass because you first have unzip the file then you have unpack them but when you unpack them they are not in folders for the item that you want to install them you have to find the install icon and put them in a folder and put a shorted cut to make it easier to install them
                          Then installing the drivers another pain in the ass because this is not straight forward either the Ethernet card there are two different one that were used and to find the installation icon just about drove me MAD finding it
                          The chip setup installation icon was almost has hard to find
                          The sound card installation icon was not quite as hard to find
                          To find all of the installation icon you have to go into every folder to find them ( really )
                          I have them on a USB thumb drive so now it should not be as much as a pain in the ass the first time
                          One final note
                          I do have every device drivers installed and everything seems to work correctly the only thing I have not done yet is going on the internet with it yet
                          This brings to a very big question and that this what version of Windows Internet Explore do I use for this
                            • 31278
                            dont use windows explorer.
                            look here:
                            https://get.geo.opera.com/ftp/pub/opera/
                            look in the "win" folder
                            • R_J
                              • Jun 2012
                              • 9621
                              If you are using windows XP , what service pack is it at? It needs to be sp3. before I would connect to the internet. You can download SP3 with another pc and place it on your usb drive and install it from there.
                              Right click on My Computer, Click on Properties, It will list the Service pack under General, System:
                              You can also use Firefox ESR version 52.9.0 for a browser.
                                HP Slim Desktop S01-af1132a Slim Desktop i3-10100 Specification for Upgrade or Repair
                                This specification for the HP Slim Desktop S01-af1132a can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-af1132a boardview and Slim Desktop S01-af1132a schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                09-12-2024, 03:28 PM
                                HP Slim Desktop S01-aF0011ns Slim Desktop J4005 Specification for Upgrade or Repair
                                This specification for the HP Slim Desktop S01-aF0011ns can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-aF0011ns boardview and Slim Desktop S01-aF0011ns schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                HP Slim Desktop S01-aF0010ns Slim Desktop J4005 Specification for Upgrade or Repair
                                This specification for the HP Slim Desktop S01-aF0010ns can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-aF0010ns boardview and Slim Desktop S01-aF0010ns schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                HP Slim Desktop S01-pD0117d Slim Desktop i3-8100 Specification for Upgrade or Repair
                                This specification for the HP Slim Desktop S01-pD0117d can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-pD0117d boardview and Slim Desktop S01-pD0117d schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
                                HP Slim Desktop S01-aF0005na Slim Desktop S01 J5005 Specification for Upgrade or Repair
                                This specification for the HP Slim Desktop S01-aF0005na can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-aF0005na boardview and Slim Desktop S01-aF0005na schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
