pool light
  • capwizard
    • Jun 2016
    • 1991
    pool light
    My pool light went out (Pentair 77163102 AquaLight Halogen Quartz Light with Stainless Steel Face Ring and 30-Feet Cord, 120-Volt, 250-Watt) because wires inside the connector to lamp base are burned and i don't want to pay $200 for a new lamp base with wire cable and $20 for quartz lamp (picture 1,2) so i modified $20, made in China, DC12v 10W, 900LM, IP67 Waterproof, with Remote Control , RGB led light onto it.
    but it leaked water so i have to open it.....
  • capwizard
    • Jun 2016
    • 1991
    Re: pool light
    then i siliconed it but i need to dive-in to use remote. i should move the IR sensor to outside.
    The RGB floodlight of disappointment.
    https://www.youtube.com/watch?v=1UAQ73BGVaM
    10W Color LED Flood Light with Remote Control Review and Teardown
    https://www.youtube.com/watch?v=eNNnI4zPpG8
    Reverse Engineering: RGB LED Bulb With IR Remote
    https://www.instructables.com/id/Rev...ith-IR-remote/
    Hijack RGB Flood Light With Arduino or ESP8266
    https://www.instructables.com/id/Hij...no-or-ESP8266/
    • capwizard
      • Jun 2016
      • 1991
      Re: pool light
      this article help me Identify the part number of U1.
      I got a similar device and spent a while playing with it.
      Mine uses a fixed PWM period of 6400 µs (156.25 Hz), divided into 80 x 80 µs ticks (12.5 kHz PWM clock). The LEDs are wired common anode so the low side can be switched.
      The 8 dim levels are 12.5, 25, 37.5, … 100% on, 10, 20, … 80 out
      of 80 ticks of on time.
      The “DIY” buttons support 28 dimming levels, which are 0, 3, 6, …, 75, 78 or 80 ticks of on time.
      The fades use single-tick increments.
      Internally, there’s an 8-pin PIC12F5xx microcontroller (with the P/N sanded off, but the power pin locations give it away) connected to an Atmel 24C02N I2C EEPROM.
      The pin assignments are:
      1- Vcc (generated by a series diode, 680Ω R, and 4.7V zener)
      2- SCL (10K pull-up)
      3- SDA (5.1K pull-up)
      4- IR input (another giveaway this is a Microchip part)
      5- Blue output (470Ω to the gate of the low-side transistor)
      6- Red output
      7- Green output
      8- GND
      There’s a 0.1 uF capacitor in parallel with the zener diode.
      The IR receiver is powered through a 100-ohm resistor followed by a second 0.1 uF decoupling cap.
      I haven’t tried dumping the PIC program ROM.
      • capwizard
        • Jun 2016
        • 1991
        Re: pool light
        I try to add more lights around the pool to create the atmosphere in these videos
        https://youtu.be/bltS2mQfeHk
        https://youtu.be/rijNg5OEtNU
        https://youtu.be/cl9m8TBychg
        • Retro-Hipster
          Tinkerer
          • Apr 2019
          • 125
          Re: pool light
          Nice! I should do the same...
          Just need a pool first.. And a house.. ☺️
          “Men always seem to think about their
          past before they die, as though they were
          frantically searching for proof that they
          truly lived.”
          – Jet (Cowboy Bebop) -
            Lithonia Lighting versus Light of America Compact Fluorescent product quality
            by sam_sam_sam
            I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
            I also have back when Light of America had these light bulbs available for yard lights
            The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
            While the Lithonia lighting fixture has all most certain bulb failure
            So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
            I have only had this light fixture for not more than a year if it...
            07-02-2023, 03:45 PM
            LG Gram Ultra-light Weight Notebook Specification for Upgrade or Repair
            This specification for the LG Gram Ultra-light Weight Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-light Weight boardview and Ultra-light Weight schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-07-2024, 03:40 AM
            LG Gram Ultra-Light Laptop Notebook Specification for Upgrade or Repair
            This specification for the LG Gram Ultra-Light Laptop Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Ultra-Light Laptop boardview and Ultra-Light Laptop schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
            09-06-2024, 09:10 PM
            09-06-2024, 08:40 PM
          • serious_electron
            Strange! Acer laptop not powering on but charging the battery (orange light on when charger and battery plugged in).
            by serious_electron
            Hello Everyone!
            I have an Acer Aspire A315-42 laptop. I generally leave it on for long time by closing down its lid (so it enters the sleep mode). Recently, it rained quite heavily in out area. And the humidity and moisture seem to be high. So one late evening, after I opened the lid and turned on the laptop, it did power on as the blue light turned on but after it booted to the desktop screen, just 5-10 seconds after both the screen and blue light went out and laptop shut down (the blue power light turned orange). And after 2-4 seconds that orange light went off and the laptop died.
            06-28-2025, 02:57 PM
