Replacing 1uF 450V AC ?
  • bianchi77
    • Jun 2016
    • 1121
    Dear Members,
    Is it possible for me replacing 1uF 450V AC (black color) with 470nF 275V AC (blue color)
    It's fan capacitor.
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8706
    Re: Replacing 1uF 450V AC ?
    uh ... no...?
    Half capacitance and half working voltage...that seems really far off?
    The capacitance is dependent on the phase angle needed, should stick with what was calculated from the design...
      • Jul 2011
      • 6070
      Originally posted by bianchi77
      It's fan capacitor.
      Because of this you need to have the right type of capacitor other wise the motor might not start running or run to fast and or over heat
      I hope this helps
      • bianchi77
        • Jun 2016
        • 1121
        can it be replaced with 2uF 475V VAC capacitor ?
        Anyone knows how to calculate it ?
        It's 240V AC 40W 50Hz motor in series with that cap, it's related with XL and XC impedance.
        • eccerr0r
          Solder Sloth
          • Nov 2012
          • 8706
          It depends on how the motor was constructed - how many degrees the rotor and the stator needs to be skewed in order to give maximum torque. Line frequency is only part of the equation and it's the only fixed portion that we can even assume...
          You can try substituting if you wish. There's no guarantees expressed or given, but the voltage rating must be honored else you likely will end up with a fire.
          • bianchi77
            • Jun 2016
            • 1121
            Ok, thanks for the info, in this case I need 475 V AC voltage rating must be honored, got it.
