Re: Unknown Surface Mount Component
they are used in chinese lights in groups of upto 8, i'm sure there wont be a problem.
Page 4 of the AMC7135 spec sheet has the Pd calculation.Leave a comment:
STJ suggested the AMC7135 ... it looks pretty tight ...Leave a comment:
It took a fully charged 18650 like a champ and managed to source 1.4 amps from it ... damn near burning my skin before it ever fried, so it's a pretty decent LED ... What I really want to do with this thing is power it from a couple of 18650's at a respectable brightness - maybe 200ma .... with just an on / off feature, no blinking or any of that fancy stuff. I might just stick with the LMN317 constant current config ... seems to be reliable although maybe a little too lossy ...
Build it and take some data.Last edited by budm; 11-07-2018, 10:44 AM.Leave a comment:
then you need one of these:
they are made for this job, if you want more current you just put 2 or more in parallel.
you get a strip of 10 for under $2 on aliexpress.Attached FilesLeave a comment:
It took a fully charged 18650 like a champ and managed to source 1.4 amps from it ... damn near burning my skin before it ever fried, so it's a pretty decent LED ... What I really want to do with this thing is power it from a couple of 18650's at a respectable brightness - maybe 200ma .... with just an on / off feature, no blinking or any of that fancy stuff. I might just stick with the LMN317 constant current config ... seems to be reliable although maybe a little too lossy ...Leave a comment:
seriously?
that's rare.
well they could be anything - .5w, 1w, or 3wLeave a comment:
well a Q5 is 350mA and a T6 is 700mA - assuming your not overdriving them.
if it has zoom or you have a magnifier,
a Q5 has 3 rectangular segments and a T6 has 6.Leave a comment:
https://www.ledgroupbuy.com/cree-model-comparison/
When you bought that flash light, what does the seller say/claim?Leave a comment:
The diameter of the PCB is exactly 20mm ... and I looked on the LED for ANY identifying markings, and I found none .... HOWEVER ... when I connect a 4.2 volt 18650 battery directly to the LED (no current limiting resistor at all), it lights up like an angel from heaven just popped in the room ... and it draws 1.5 amps which I feel is WAY TOO HOT to run that led ... but at least we know what it CAN do although it got hot so fast, I think it might burn out at that kind of continuous draw ... when I put a CC power supply on it at no more than 4.5 volts at 250ma its nice and bright..... if that tells you anything ...Leave a comment:
It appears to be flashlight LED controller + MCU. Some IC's have linear constant-current control and others have buck converter to do that for higher efficiency.
My guess is YX8133A by shiningic but hell to translate. Replaced by YX8231B or YX8232B. I can't find much for SMD marking codes.
If you have an inductor stashed away somewhere, it is a buck-converter type.Leave a comment:
Or it has just ON and OFF.Leave a comment:
What do you mean by "100% or off - no multi-mode"?Leave a comment:
it's a chip - custom.
did you remove some resistors?
those chips only handle 1.4A, the board usually has some parallel resistors to limit the led current.
if your trying to fix it, you can bypass it for 100% or off - no multi-mode.Leave a comment:
TE Circuit Protection offers the widest selection of surface-mount fuses available for addressing a broad range of overcurrent protection applications. Helping to prevent costly damage and promote a safe environment for electronic and electrical equipment, our single-use chip fuses provide performance stability to support applications with current ratings from .5A up to 20A.
TE Circuit Protection also offers the telecom FT600 fuse for telecommunications applications. This telecom fuse helps comply with North American overcurrent protection requirements, including Telcordia, GR-1089,...-
Channel: Common Parts Library - Datasheets
10-07-2024, 06:07 AM -
This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock boardview and Surface Book 3 + Surface Dock schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...09-06-2024, 08:10 PM
This specification for the Microsoft Surface Book Surface Book 3 + Surface Dock 2 Hybrid (2-in-1) can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Surface Book 3 + Surface Dock 2 boardview and Surface Book 3 + Surface Dock 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note...09-06-2024, 08:10 PM
- Loading...
