Overvoltage protection design ideas
+ More Options
Posts
  • ben7
    Capaholic
    • Jan 2011
    • 4059
    Re: Overvoltage protection design ideas
    The simplest thing I can see doing is to connect a suitably sized power transformer across the AC input before the UPS transformer, and connect the output of the power transformer in series, anti-phased, with the UPS transformer primary winding. This will reduce the input voltage that the UPS transformer sees, thus reducing it's output voltage.
    (Note that connecting the output of the power transformer in-phase with the AC will INCREASE the voltage the UPS transformer sees.)
    Of course, this might cause more voltage drop during high loads, but it will give you headroom so that if the mains input is higher, you won't violate the DC-DC regulator input voltage ratings.
    As for other solutions, there are ICs made by some manufacturers that can drive FETS, used as electronic fuses, or surge stoppers.
    Check the LTC4366 as an example.
    -Ben
    P.S. In the case of the LTC4366, you'll need to make sure the FET can handle the power dissipation if/when there is a surge. So pick a FET that has a large SOA (Safe Operating Area). You'll need to make sure you set the overvoltage timer, so that the transistor is kept under it's SOA. (SOA varies, depending on time and power dissipation.)
    P.S.2. The LTC4366 is a small chip, dunno if you would be able to solder it! Linear Technology has some other similar chips, possibly in a larger package, so you should check out their site.
    Muh-soggy-knee
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      That LTC chip looks very interesting and fit for the purpose. Had a look at its datasheet - looks complicated in there but I'm sure I'd be able to pull through. Soldering hasn't been an issue to me for quite a few years on, so no worries there It actually HAS to be small, since space inside my enclosure is very limited....I'd still need the series pass element to be bolted to a heatsink which requires additional space, so I'm not sure if it's doable at the end of the day...
      Wattevah...
      • Badee
        • 7
        that sure is interesting. any new updates about it?
        • redwire
          • Dec 2010
          • 3912
          LTC4366 used on a 24V truck electrical system, and they all died.
          Lovely datasheet and the IC looks good but it cannot take any negative input voltage spikes- common occurrence in a car or truck. Have to add a bunch of circuitry for that, Fig. 8.
          You can either clamp an overvoltage spike, turning it into heat in some component (i.e. TVS, MOV etc.); or you can switch off power or ride-through the overvoltage like the LC4366. The MOSFET gets very stressed in linear-mode trying to regulate say 24VDC out and 250VDC input spike.
          • Dannyx
            CertifiedAxhole
            • Aug 2016
            • 3912
            So basically there is no "ideal" solution and it's all about compromise from what I gather. The simplest form is to just put a zener diode across the thing you want to protect and have it blow the fuse if it exceeds the zener voltage. In a car, I assume this wouldn't work to protect a small electronic device because the thing would blow fuses every time when there's a spike over the zener voltage like when the car starts. Makes me wonder how headunits and amps are designed, since those connect straight to the battery, so they're constantly exposed to ramps and spikes.
            Wattevah...
            • Longbow
              • Jun 2011
              • 623
              There IS an ideal solution to your problem, as described. A box of units cobbled together is not going to require high level engineering for you to get into operation. In fact, at this point you don't even know if your unit will function as expected over a long haul. You have a very common requirement for inrush protection. In this case you are not too worried about overloading the mains, but simply providing a soft start situation for your equipment. Thermistors are used industry-wide on all types of equipment and I recommend that solution because it is relatively simple, inexpensive and effective. The only difficult part is finding the correct resistance value and dissipation.
              Is it plugged in?
              • caspian
                What Zener Diodes on a Linear Power Supply
                by caspian
                Dear members,
                I have a linear variable power supply with unknown brand name that I used for voltage injection.
                Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
                In addition, I discovered that its zener diodes are defective.
                I can replace the burned transistors.
                But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
                Therefore, I cannot replace the zener diodes.
                I do not want to test the zener diodes in a test circuit to discover their model or value.
                no schematics are available...
                05-26-2025, 12:38 PM
              • Dvsr
                On M-Audio AV40 active studio speaker's two zener diodes get really hot.
                by Dvsr
                Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
                I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
                After replacing the caps I started testing out the speaker. It seemed...
                Yesterday, 10:20 AM
              • nev1001
                What zener diode might fix the sound on Maestro Mayhem gaming chair?
                by nev1001
                Hi, I'm looking for a bit of help trying to fix the audio unit from a Maestro Mayhem 4.1 gaming chair please.
                The chair has a few speakers and vibration motors. All was well, for a while, but now the sound is gone.
                It may be significant that I discovered my son was powering it with a 19V laptop charger when it should run on 12V - it did fully work, for bit.
                I think an issue could be a zener diode (or capacitor) which has shorted out.
                The board's bluetooth input still works, the vibration motors are working, so is the line out socket but not the...
                04-17-2025, 05:09 PM
                NTE Electronics “NTE5251K” Zener Diode 9.1V @ 50W Do-5.5% Want to build a 9.1 output from a 9.6 lipo4 battery pack
                I have bought this Zener Diode for this project what size and wattage resistor value do I need to use to get near 50 watt output
                I bought this from an eBay seller but unfortunately they only had one
                I bought three from Vetco Electronics these are Sylvania ECG5185A 9.1@10w A to Stud what size and watt resistor do I need to use to get near 10 watt output
                I bought three of from them to also make battery packs with this output power limit in mind
                I want to use this battery pack and turn it into a 9.1 output battery pack output to eliminate using 9 volt battery...
                04-23-2025, 05:50 AM
              • unimatrix93
                TV backlight zener diode
                by unimatrix93
                Hello everyone, I'm repairing an LG TV backlight and I noticed some strange behavior when I touching the backlight strip with a missing Zener diode.
                So I replaced the leds on the strips and they seemingly working fine, but soon as I touch the strip which has a missing Zener diode the whole backlight turns off for a few seconds and then turns back on.
                Is this caused by the missing diode? If so what kind of zener diode should I use to replace it?.
                The led strips has 9 6V leds.
                02-10-2025, 12:13 PM
