ndf-68n electric fireplace diagram needed
  • tonytiger
    • Jan 2010
    • 163
    • canada
    hi guys.
    im looking for a wire shematic,diagram,ect for a electric fireplace that a custumer brouth me all wires have been un-plug and no diagram inside of fireplace....
    the only info i have is the inser model:
    NDF-68N
    hope someone can help me out here.
    thank you
    • Jul 2011
    • 6039
    Re: ndf-68n electric fireplace diagram needed
    I found a parts list here at this link
    I also found this link https://www.manualslib.com/manual/95...48bho-Bdc.html
    But I could not find wiring diagram for this heater but it should be straight forward you have the heater element and a thermostat and a fan from looks of the parts list unless it is a gas heater the that is a horse of a different color
    • tonytiger
      • Jan 2010
      • 163
      • canada
      thanks for the part list will be useful,now just hoping to fing that diagram.
      • tonytiger
        • Jan 2010
        • 163
        • canada
        i did find this one also,but more for the wood parts,but thanks for looking out.
        • tonytiger
          • Jan 2010
          • 163
          • canada
          yes it is electric and yes i guest i will try to re-connect it myself.thanks for replying.
          • Chapita
            Dell latitude 5289 schematic diagram a d board view needed
            by Chapita
            Hi friends, anyone to assist with the schematic diagram and boardview for dell latitude 5289 with board number CAZ LA-E111P....
            09-15-2024, 03:18 AM
          • businessmind1988
            HP CQ61 SCEHMATIC DIAGRAM NEEDED
            by businessmind1988
            please i need schematic for HP CQ61
            mobo number DA00P8MB6D1 REV
            09-28-2024, 07:59 AM
          • hs5424
            Dynacord powermate 1600 block diagram.
            by hs5424
            Hi All,
            I obtained a schematic diagram for the above mixer but I am wondering if a block diagram exists as I am trying to fix a problem in the protection circuit which I find a little confusing using a circuit diagram only. In the good old days the workshop manuals always had a block diagram with a circuit discription. Very useful for fault finding.
            The protection light is perminently on. The right sode has a -80DC on the feed to the speaker, hence the protection led on. I have removed all the O/P transistors which checked out OK. I tested all other transistors in circuit which seem...
            07-31-2025, 01:35 PM
          • Techmanx
            Schematic Diagram Needed
            by Techmanx
            I have a Yorkville Audiopro 208 Performance Mixer (full name on device - 8 channels, non-powered). Not only can I not locate schematics for this, I cannot find a user manual, a picture or any reference whatsoever to this mixer on the entire internet and I have looked really hard. Not a single mention anywhere. It's like it never existed, yet it does. I have been sourcing schematics for decades but have never run into to this before. In this day and age, how is this even possible?
            It appears to have the same mixer stage as the Audiopro model 508 but this unit has a built in power...
            07-05-2023, 01:41 PM
          • Yanleb
            Muskoka MH25BL-1 Electric Fireplace no power
            by Yanleb
            I just want to document and share the repair of my Muskoka MH25BL-1 electric fireplace that has no power.
            The main board model is MH36BL-MAIN. I found R1, a 3.9M ohm 1/2W 5% resistor to be open in the power-supply section. After replacement the fireplace works like new.
            I hope this will help someone.
            04-05-2020, 03:04 PM
