Dell 1800FP Power Supply Question
  • badrianiulian
    • Apr 2012
    • 43
    Hello
    I don't know where to find this answer
    I found a working Dell 1800FP Power Supply ( 6870t445d10 ) and I was wondering if anyone knows it's specifications ? I mostly would like to know how many amps do the 5V and 12V provide?
    Thank you
  • Tynan Dill
    by Tynan Dill
    Assuming...
    11-22-2024, 01:46 PM
    03-31-2024, 02:12 PM
    07-01-2024, 06:34 AM
  • JimBanville
    Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
    by JimBanville
    The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
    I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
    09-13-2023, 07:21 AM
  • Info13
    Dell H235P-00 Power Supply Failure
    by Info13
    A H235P-00 power supply unit from a Dell Optiplex 760 PC is faulty.
    After removing it from the computer, I placed a paper clip between the green and black wires, then connected it unloaded to the mains through a series lamp.
    ➡️ First test:
    The PSU partially works: the green indicator LED lights up, and the fan starts for one second, then stops.
    A click can be heard at the moment it stops. The series lamp lights up when the power supply starts, then turns off when it shuts down.
    I then followed the advice from the forum and replaced...
    10-22-2025, 01:52 PM
