How accurate are some Capacitor specifications?
  • Xenofenix
    • Sep 2015
    • 13
    • US
    I think I changed my capacitor with an incompatible one, and I'm about to purchase another, but I'm a bit confused on the information.
    Here is the information on the capacitor I need to replace:
    The 10A 470uF. The ESR max is 20mOhm?! That's ridiculously low I think (I am browsing digkey for a replacement. Even here, when I looked at the 470uF 10V capacitor that badcaps sells, the sheet said .072ohm =72mOhm
    https://cdn.badcaps-static.com/pdfs/...d3dded1822.pdf
    I'm not sure how close this number needs to be, but I'm trying to get as close as possible.
  • Xenofenix
    • Sep 2015
    • 13
    • US
    Re: How accurate are some Capacitor specifications?
    I retract my question! When I went looking for "polymer" caps like the one I'm trying to replace, I found many caps around and UNDER that range. I'll leave everything in case some one else has the same question
    • MORETTIGIAN
      by MORETTIGIAN
      Title:
      Description:
      Procedure performed:
      - Removed backplate
      - Reapplied thermal compound
      - Reassembled card
      09-18-2025, 12:14 PM
    • Prolog
      by Prolog
      12-01-2024, 08:27 PM
    • chth96
      by chth96
      12-22-2023, 04:34 AM
    • chth96
      by chth96
      06-02-2024, 07:31 PM
    • chth96
      Is it no harm to replace with capacitor without ripple current rating?
      by chth96
      When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
      Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
      But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
      Rubycon YK DataSheet (b...
      04-19-2024, 05:19 AM
