UCC LL Series
    UCC LL Series
    I'm looking for the datasheet for the Nippon Chemi-con LL series, used in the 70's. Trying to figure out why the schematic for my reel to reel lists them as "10uf, 25wv (NL)" The other 10uf caps do not have the (NL) after them. At first I thought they were bi-polar, but they are not.
    I have some bi-polar caps here, but I'm not sure I want to use them. These are all caps used in the audio circuits.
    Re: UCC LL Series
    I found out that these are Low Leakage caps. Panny FC series should be fine for this, shouldn't it?
      Re: UCC LL Series
      Some caution here. Low leakage caps are different. Low ESR caps are not focused on low leakage, usually because they are applied to high current circuits. Low leakage are applied to low current, higher impedance circuits where leakage may impact on the DC operating conditions. The leakage is similar to tantalum, you could replace with 10u 25V tantalum.
      Gigabyte EP45-DS3L Ultra Reliable (Power saver)
      Intel E8400 (3000Mhz) Bios temps. 4096Mb 800Mhz DDR2 Corsair XMS2 4-4-4-12
      160Gb WD SATAII Server grade
      Nvidia 8500GT 256Mb
      160Gb WD eSATAII Server grade for backup.
      Samsung 18x DVD writer
      Pioneer 16x DVD writer + 6x Dual layer
      33 way card reader
      Windows XP Pro SP3
      Thermaltake Matrix case with 430W Silent Power
      17" Benq FP737s LCD monitor
      HP Officejet Pro K5300 with refillable tanks
        Re: UCC LL Series
        I don't want to use tants unless I have to... I've had way too many problems with them in audio circuits in the past. They cause all sorts of random noise and crackling when they get to be a few years old.
        Maybe I'll just leave the originals in place and recap the rest. It sounded good before, but I want it to be 100% reliable.
        Would poly or mylar be ok, if I can find them small enough to physically fit?
          Re: UCC LL Series
          What kind of caps you need? May be i can give you some helps with Samxon.
          My SAMXON Capacitors Database HERE!!
          X-CON is a new brand for SAMXON's Polymer Capacitors.
            Re: UCC LL Series
            Yes if they fit would be excellent.
            Nvidia 8500GT 256Mb
            33 way card reader
            Windows XP Pro SP3
              Re: UCC LL Series
              Joe, He needs 10uF 25V in a Samxon L series. Can you supply?
              Nvidia 8500GT 256Mb
              33 way card reader
              Windows XP Pro SP3
                Re: UCC LL Series
                Yes, i can supply Samxon LL Series (Low Leakage Type). Is it 10uF 25V D5x11 suit or not?
                  Re: UCC LL Series
                  Thanks Joe. Now Maxxarcade has a choice to get some from you.
                  Nvidia 8500GT 256Mb
                  33 way card reader
                  Windows XP Pro SP3
                    Re: UCC LL Series
                    Hi Joe,
                    How does the Samxon LL compare to these?
                    https://cdn.badcaps-static.com/pdfs/...3758aead7c.pdf
                    The Xicon are $0.24 each. How much are the Samxon LL? I need 8 of them I think.
                      Re: UCC LL Series
                      Originally posted by Maxxarcade
                      Hi Joe,
                      http://www.mouser.com/catalog/specsheets/XC-600175.pdf
                      Here is Samxon LL datasheet, you can download and compare with Xicon.
                      http://www.samxon.com/PDF/prodPDF_51.pdf
                      If you are not hurry, i can send you free of charge.
                        Re: UCC LL Series
                        Thanks Joe, you're the best! Do you still have my shipping address?
                        I was hoping to get the project done in a week or so, but I can wait a bit.
                        It looks like the Samxon may be slightly better than the Xicon. They have higher temperature range and just a bit less leakage.
                        After it is done, I will post a video on Youtube of it running, and will give credit to those here who helped me find caps and stuff
                        Next restoration project is my old Sony TC-200 from 1964
