SOT 23 package identification
  • mitsu2k
    Power-One solar Inverter driving me NUTS!!!
    by mitsu2k
    Hello folks, this is a last ditch effort. I thought I would seek your expertise before giving up.. I have been working on this thing for over 2 months and have gotten nowhere. Here is the issue:
    Inverter powers on and immediately red GFI light comes on and inverter will not complete the initialization process.
    There is no error code on the screen. I have removed most of the Y capacitors and tested to no avail.
    All relays are good.
    I replaced the current transducer- same problem. Checked most of the transistors and diodes and all appear good. I wish I could get my hands...
    11-13-2023, 07:19 PM
    ISL6556ACB ISL6556ACBZ ISL6556ACR ISL6556ACRZ PWM Controller Datasheet
    Optimized Multi-Phase PWM Controller
    with 6-Bit DAC for VR10.X Application
    The ISL6556A controls microprocessor core voltage
    regulation by driving up to 4 synchronous-rectified buck
    channels in parallel. Multi-phase buck converter architecture
    uses interleaved timing to multiply channel ripple frequency
    and reduce input and output ripple currents. Lower ripple
    results in fewer components, lower component cost, reduced
    power dissipation, and smaller implementation...
    11-05-2024, 03:10 PM
    Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
    The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
    Securing a good thermal interface between...
    10-07-2024, 04:35 AM
  • Shulgin
    Acer predator XB241YU Component identification
    by Shulgin
    I have a problem with my Acer predator XB241YU screen. When I plug it in, the startup LED turns on instantly, and I can't turn off the screen without unplugging it.
    After disassembly and inspection of the electronic cards I found what looks like a broken inductor, it is marked with the letter A and is at location L58.
    In the first photo you can see the broken component, in the second photo you can see where it is on the board, in the third photo you can see the silkscreen and in the fourth photo you can see the identification sticker of the main board
    I...
    05-11-2024, 11:06 AM
  • thebomb602
    ASUS GA402R IC identification
    by thebomb602
    Hey guys! my name is kyle, new to motherboard troubleshooting and a little confused still on chip identification if yall could help identify this chip..
    also if you could teach me how to fish on this particular topic... i did read through the ic identification sticky, and couldnt identify this with that info... thanks!
    EDIT, just realized thats a 5 and not an S in the first line... finding results for it now. cant figure out how to take down thread so im not embarrassed...
    11-21-2023, 02:30 PM
