questions about dc Charger or Battery
  • lorins_core
    BlackSmith
    • Dec 2012
    • 552
    • Philippines
    hello the may i have a question
    Why is it that when I test a 19v charger, it reads 19.40v higher on the volt meter?
    why?
    thanks for response
    • Jul 2011
    • 6070
    It could be that your meter is off a little bit or the switching power supply is set up that way or if it is a linear power supply which in general they are not regulated very well sometimes
    it would help if you posted a picture of the power supply in question so we can give you a better idea and answer to your question
      NVDC charger configuration...
      11-05-2024, 03:28 PM
      ISL6257HRZ ISL6257HRZ-T Laptop Battery Charger Datasheet
      Highly Integrated Narrow VDC Battery Charger for Notebook Computers
      The ISL6257HRZ ISL6257HRZ-T is a highly integrated battery charger controller
      for Li-Ion/Li-Ion polymer batteries. ISL6257 is designed for
      Narrow VDC applications where the system power source is
      either the battery pack or the regulated output of the charger.
      This makes the max voltage to the system equal to the max
      battery voltage instead of the max adapter voltage. Operating
      at lower system voltage can improve...
      11-05-2024, 04:43 PM
    • flat-earther
      how to prevent a connected charger from draining battery when not charging?
      by flat-earther
      I have an RC radio handset(Taranis QX7) which doesn't have internal battery charger which means I had to remove the battery every time I needed to charge it.
      So to improve it, I added a 15W USB-C charger board(link) inside and soldered it to the same connector on the PCB where the battery plugs into, great, now I can simply charge it with a USB-C cable.
      but the problem I found is that after the radio sat for two weeks without being used the 2S 18650 battery that I'm using was at 4.2V!
      So the battery is backfeeding the charger and being drained.
      How can I prevent...
      08-07-2025, 01:04 PM
    • Bowline
      by Bowline
      06-11-2025, 10:13 AM
      Bauer tool battery pack charging with a HERCULES charger modification
      The Bauer power tool battery charger just has to many issues with the charger over heating because I several HERCULES Hercules battery chargers that are 3 amp charge and because they have gone on quite a few times over the years before they came out with the fan cooling battery charger I going to modify one so I can charge Bauer battery packs faster than the crape battery charger that they have
      Here is how this modification is going to be done I taking a 1.5 amp hour battery enclosure and gutting it removing the battery cells and replacing some Ryobi 1.5 amp hour battery pack that...
      05-06-2023, 12:17 PM
