Outrageous Acts of Science a Personal Hover Board with at least 8 fan motors on the Science Channel
    • Jul 2011
    • 6070
    This is the most interesting thing that I have ever seen on this series and I watch it when it on and I have seen a lot of episodes in the past
    I want one but wow how dangerous this is one thing that would make it more safe would be a gyroscope controller then it would make it a lot safer to operate
    Here is the website link to it
    https://www.youtube.com/watch?v=ROl1CbjJS0g
    Hopefully this is not AI generated video I would be very disappointed if it was
    One note if this post is the wrong category please move to the correct one thanks
  • clearchris
    Building a Magnetizing Fixture for Stepper Motors
    by clearchris
    I have some nema 23 stepper motors, and I'd very much like to replace the shafts. However, removing the rotor from the housing demagnetizes and damages them. These motors are assembled, and magnitized in place. The rotors are 2 pole axially magnetized, doesn't seem like a big deal.
    Here's a link with a nice picture of what I'm talking about.
    https://www.orientalmotor.com/steppe...d-control.html
    Again, doesn't seem like that big of a deal. So then, there's this demonstration of remagnetizing a servo motor, which...
    07-01-2020, 04:28 PM
  • chevellebbc@yahoo.com
    Static?? If I hover over the main board it shuts down
    by chevellebbc@yahoo.com
    Hoping for some newbie help. I had a tv in the basement for years that needed diagnosis. Finally got to looking at it. First was a backlight issue. Power supply checked out and replaced the led set. Then when the main board plugged it the backlights shut off. So pulled the main board tested as many components as possible and didn't find the culprit. So sourced an eBay one for cheap hoping it was something correctable. But now with the timing board unplugged the tv will start with backlights and stay on. However if I touch the ribbon it'll attempt to shut down. Now if I even hover my hand above...
    03-18-2023, 09:37 AM
  • jesterace
    Samsung UE49MU6400 acts dead until disconnecting backlights, then works.
    by jesterace
    Hi everyone I have this TV which was dead one day when I tried to turn it on. I've had the cover off and there was just a pulsating/electrical clicking/ticking noise from the PSU. I disconnected the mainboard as sometimes this works to just fire it up with backlights on? That didn't help. Same noise. Then I disconnected the backlight cable from the PSU and the TV came alive. It appeared to respond to the remote and i'm pretty sure it's fully operational when there is no backlight connected.
    However, I am in a dilemma.
    I tested the backlight outputs with the lights disconnected...
    10-20-2024, 10:15 AM
  • Lamer13
    Asrock B365 Pro4 PSU acts as short but no short
    by Lamer13
    The PSUs (several good PSUs tried) act as the 12v CPU Line is shorted - PSUs start and stop right away and second try through pwbtn is impossible unless psu off-on first. When CPU line not plugged PSUs run normally. This happens only when cpu line plugged. The mosfets are not shorted. Tested every single one of them between drain and source - high side mosfets - 1.3megaohm, low side - 100ohms. Between 12v and ground on the cpu connector - normal capacitor rise from ohms to about 1megaohm. All measurements are without a cpu (btw I tried with 2 different cpus - same result).
    So I suspect...
    11-03-2023, 06:52 AM
  • pavithra_uk
    Lubricating plastic wheels in geared motors
    by pavithra_uk
    What can be used for lubricating plastic wheels in small geared motors ?
    General purpose automotive grease
    Motor engine oil
    Motor Gear oil
    Silicone lubricating spray
    Rubber grease (used to lubricate orings in break calipers)...
    10-31-2021, 09:05 AM
