DMX control of old analog lighting panel ?
  • dvsapp
    • Mar 2014
    Guys, don't really know where to post this, so here goes...
    I got involved with doing an upgrade to the interior lighting system in my church.
    Existing system is an old analog Prestolite system from around 1989. We are looking at using a DMX based controller such as the Chauvet Obey 40, but the idea has come up on also using a PC controller with Q Light Controller software. I've seen USB to DMX converters out there, but not sure if there are any that would allow the user to easily switch between a panel such as the Obey 40 and a PC.
    The reason for this is the PC to be used is also used for doing live video mixing/recording of the church services for the shut-ins. Not every church service is recorded, so the PC is not used all the time.
    Welcome input from anyone who deals with this kind of thing. Also, since it's a church situation, we are looking for lower-dollar solutions.
  • bluto
    • Oct 2007
    • 560
    Re: DMX control of old analog lighting panel ?
    How many channels of dimmers are you trying to control? Since you mentioned your existing dimmers are analog, you will need a DMX to analog (0-10v) demultiplexer to connect to them. This is probably a good one: http://www.pathwayconnect.com/content/view/31/29/
    I would recommend a real light board like an ETC smartfade or even just a 'dumb' board like an Leprecon or Leviton/NSI over a PC based solution. The board that you mentioned seems like overkill since it is meant to control 'moving' lights with up to 16 DMX channels per light.
      BL0202C BL0202B BL0200C Datasheet
      The BL0202C BL0202B BL0200C are 2ch output LED driver IC for LED backlight, and it can do dimming to 0.02% by external PWM signal.
      This IC realizes a high efficiency by the boost convertor control that absorbs variability on VF.
      The product easily achieves high cost-performance LED drive system with few external components and enhanced protection functions.
      Features and Benefit
      Boost Convertor
      ● Current-Mode type PWM Control
      ● PWM frequency is 100 kHz or 200 kHz
      ● Maximum On Duty is 90%
      LED current...
      10-07-2024, 04:48 AM
    • Yanleb
      LG 60PK550 Logic Control Board EBR63450301
      by Yanleb
      Hi all, I just want to share the repair of my 60PK550-UA TV set.
      The TV set was powering on, just no image. After verification, nothing wrong on the YSus or ZSus boards. Nothing wrong on the main board either.
      But I noticed that the LED was not flashing on the Logic Control Board. This is an EBR63450301. The LED is supposed to flash even with all the flat cables disconnected, with only the power cable attached.
      All the voltages measured at the electrolytic capacitors on the board were good. From top left to bottom right:
      C57: 3.30V
      C61:...
      07-20-2023, 12:38 AM
    • harp
      triac phase control 0-100%
      by harp
      Trying to understand which properties of circuit affect triac phase range, is it possible to control near whole period, or it have some limitations - on net found a couple circuit, that claims almost full control, but in the past I build some simple circuit and remember that it do only half of control over triac?...
      06-02-2024, 09:00 AM
    • adrianekspert
      Looking for schematic – RS Welding Systems WIG-STEUERUNG (906383 / 906384, RS1)
      by adrianekspert
      I’m currently working on a project focused on diagnosing and reconstructing the control electronics of RS1 / RS Welding Systems Leipzig (WIG-STEUERUNG) welders.
      I’m looking for the schematic diagram or any technical documentation of the main control board labeled 906383 / 906384, used in RS1 TIG/MMA welding machines.
      The board includes:
      • two UBICOM TDS38070 microcontrollers,
      • EEPROM 24C256,
      • analog ICs such as LM358, TL062, MC33153, MAX4515,
      • a gas valve control section (BD135 / IRF8G30 / optocouplers P621),
      • connectors labeled Display, Netzteil,
      10-19-2025, 06:14 AM
    • FuzzyOwl
      Denon AVR-X3600H No sound even to pre outs in direct analog mode. Help please!
      by FuzzyOwl
      Hi, I have a Denon AVR-X3600H I'm trying to repair. I have no electronics repair experience but I have a multimeter, service manual and a will to fix it (https://device.report/m/d5de8c00e617...f63147aba9.pdf)
      Everything seems to work except for no sound even through the pre outs. However I will get sound using Zone 2 pre outs.
      Only digital symptom I can tell is it will soft lock when in the Speakers/Test Tone menu and be unable to adjust +/- db during the test tone.
      I've followed the trouble shooting guide, audio check...
      12-05-2024, 11:54 AM
