Idling adjustment question power amplifier
  • nonanche92000
    • Mar 2014
    • 19
    • France
    Hi ,
    There is something that i don't understand with an idling adjustment of an amplifier on the service manual (YST-SW320) :
    IDLING ADJUSTMENT :
    " To stabilize operation of the amplifier, turn ON the power with NO INPUT SIGNAL and wait for 2 to 3 minutes IN NON LOADED CONDITION before the adjustment.
    Adjust VR1 (potentiometer) so that the voltage between terminals TP11 and TP12 is DC 50mV to 250 mV. "
    What does " IN NON LOADED CONDITION " mean ?
    I think at first without the driver / woofer , but i am not sure of it.
    Thanks !
    Main Pc : core i7 2600k @ 4.2 Ghz, ga-z77x up5 th , raptor WD 300Go , 16 Go crucial ballistix 1600 Mhz ,Asus Strix GTX980 DC2OC , Cooler Master storm trooper , Corsair AX860i.
    Laptop : Asus X73SV-TY549V
  • rhomanski
    nowhere man
    • 5157
    • U S of A
    Re: Idling adjustment question power amplifier
    Generally, the only thing plugged in would be the power cord. Volume at lowest setting. Usually your looking at mV, so a self ranging fluke works perfect. That range is very large for yours. Most are like +-2 mV or something.
    On one of mine you have to close it up and let it cook for a half an hour for it to settle down. Then open it up and do the final adjustment which is 20 mV +- 2mV.
    sigpicThe Sky Is Falling
    • redwire
      • Dec 2010
      • 3912
      You always set power-amp bias current with no load connected, and zero signal.
      Because you only want to measure output-stage current (mV across emitter resistors) not including (idle) current into the speaker, dummy load etc.
      I let amps warm up and temperature stabilize for 20-30minutes. That 2-3 minutes figure is for the production line where you are in a hurry.
      • rievax_60
        • May 2012
        • 897
        • australia
        50mV to 250 mV seems unusually high. What value are the emitter resistors and how many are there per channel?
        • redwire
          • Dec 2010
          • 3912
          The emitter resistors are 0.15 ohm each, but you are measuring 50-250mV across a 22R resistor in the what looks like the class-G boost switch. That would be a quiescent current of 2.3-11.4mA, close to cutoff but it's a subwoofer amp. YST-SW320 schematic here
          • rievax_60
            • May 2012
            • 897
            • australia
            Yes, that makes good sense now.
            • nonanche92000
              • Mar 2014
              • 19
              • France
              Thank you guys for all your answers.
              So if i'm right , after 30 min of warm up (instead of 2-3 min on the service manual) , without input , and without the speaker, value beetween this two terminals TP11 and TP12 should be somewhere between 50 and 250 mV DC on the voltmeter and with the volume set to the minimum?
              I did a full recap , but with exactly the same capacitors series ( panasonic M and chemicon SMG )
              thanks!
              • redwire
                • Dec 2010
                • 3912
                Yes that's the best way to check bias.
                If you are adjusting it, the loop is to measure bias, readjust, wait, remeasure, readjust, wait ... and so on. Because, if you adjust bias current the heatsink temperature will change too and it needs time to settle at the new temperature. Most amps settle in ~10 minutes.
                • Mark R
                  Marantz Model 150 Tuner "NULL" Adjustment..
                  by Mark R
                  I am not ashamed to say this is my first FM alignment I have ever done. I am well versed in electronics and repair. Been doing it for many years on Pro Audio Live sound equipment. Worked on Power amps EQ's musical gear and Large format Mixing Live consoles Etc. But now I can see this is a whole different world when it comes to tweaking this kind of gear. I do have the proper gear like the SENCORE SG 80 and HP Generators and Scopes Etc.
                  Look below at Adjustment 12:8. The Null adjustment. I have a Heathkit IM-28 VTVM that was rebuilt and has new Burned in tubes that I used for this...
                  12-30-2024, 03:18 PM
                • MrCommunistGen
                  Polk Audio RTi100 Plate Amplifier won't power on and intermittently honks and buzzes
                  by MrCommunistGen
                  My childhood best friend was killed about 9 years ago. His parents are finally letting go of his things, and they offered me his Polk RTi100 tower speakers. The Polk RTi100 towers are one of a handful of designs from the early 2000s that is a full range 3-way tower with a built-in self-powered subwoofer. This is accomplished with a plate amp integrated into the speaker input panel.
                  I think they used them for a while, but they've been sitting for at least a few years now. After about 40 hours of driving to their house and back (both they and I have moved in the last 9 years) I got...
                  07-12-2021, 05:11 PM
                • jinu_j
                  How to test Subwoofer Amplifier with only a multimeter
                  by jinu_j
                  Hi Folks
                  Need some advice on how to test a subwoofer amplifier if i have access to only a multimeter.
                  Problem
                  I have a Boston Acoustics active Subwoofer (soundware S). Its rated output is 200W. But the output i am getting is very low i can barely hear/feel it even if put the gain at max. I replaced all the capacitors in the Subwoofer amplifier but still no change.
                  Is there anyway to test this without getting an oscilloscope/Function generator to see if the fault is with amplifier, driver or the source??
                  Any advice would be appreciated...
                  08-29-2024, 02:05 AM
                • UserXP
                  Mackie CR4 amplifier no sound
                  by UserXP
                  Hi, people.
                  I've got an amplifier assembly from Mackie CR4 parts. It's just an amplifier, there was no speaker housing, so I used my set of CR4s to test it.
                  Anyway, upon connecting everything and hooking the "new" amplifier to an audio source, the sound played clearly and strongly for the first ten seconds. I was happy it was working. Then the sound started to fade out during the playback until it was no more. After it had "dropped to zero", there were two very short intervals of sound playing at the normal volume, as if the amplifier was trying to...
                  10-17-2020, 05:06 PM
                • mikey5791
                  Help on car amplifier only one channel works
                  by mikey5791
                  Hi all forum members,
                  Fyi, i have been working on this old model PCT-4082 (4 channel car amplifier). The owner said only one channel is working.
                  My initial finding is this amp originally use Toshiba 2SA1943 and 2SC5200 transistor for its output but after opening the top casing i found it used Toshiba A1941 (pnp)and C5198(npn). I desoldered all the 4 pairs transistors and found 1 piece A1941 open(tested "OL" on all legs) and replaced the 1st pair with 2SA1943 and 2SC5200, thats why you can see in the picture it is the bigger size transistor. The other A1941 and C5198 all...
                  08-06-2025, 10:36 PM
