Chip identification
  • Crystaleyes
    • Sep 2021
    • 500
    • Brazil
    Chip identification
    Hello everyone.
    I picked up a cheap kitchen liquidiser at the local flea market which perhaps unsurprisingly doesn't work. It has a remarkably sparse control board with one SOP 20 controller in the middle, which I cannot find any info on.
    If I'm not mistaken the number is TG49141AX07 with ATL1000 and 01 12 19 (date?).
    Any ideas as to where a datasheet might be found?
    Thanks in advance
  • truclacicr
    • Apr 2019
    • 377
    • australia
    Have you measured anything? Can you tell us the Vcc voltage? (between pins #20 and #10 ?)
    Does this appliance have a transformerless power suply?
    • Crystaleyes
      • Sep 2021
      • 500
      • Brazil
      I haven't measured any voltages but yes, it has a transformerless power supply.
      The next thread was actually going to cover this
      • DynaxSC
        ASRock B650M PRO RS - BIOS CHIP 25Q256JW BLOCKED BY STATUS REGISTERS
        by DynaxSC
        Hi
        I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6...
        08-04-2025, 12:20 PM
      • e-repair
        Chip identification on hp omen 17cb1008tx
        by e-repair
        Hello !
        i have an to repair an hp omen 17cb1008tx.
        i have a short on a power supply chip, sempt powering the chipset. the chip was burned, but i can read the chip making code but i can't find any references. chip reading is AWSBVC. the chip have an output directly on a coil. sempt to have no damage on the rail behind but can't confirm.
        can you help me find a reference for this ic ?...
        09-23-2025, 03:38 AM
      • Sunday1302
        Need help with GIGABYTE B550 UD AC REV 1.0 chip identification
        by Sunday1302
        I removed this chip with markings "14 8A SA4" between an HDMI port and a USB port that was faulty. I need to replace it, but I have not been able to properly identify this chip using the markings provided on the chip itself. If anyone is able to provide information regarding this chip, I would greatly appreciate it....
        10-26-2025, 02:35 PM
        Common SPI bios chip programming Questions and Answers
        by SMDFlea
        Q: I have a bios request,i can`t post my backup as i can`t read from the chip.
        A: If you can`t read from it how do you expect to write to it ?.
        Q: Why is my bios chip unreadable ?.
        A: The programmer is faulty or has a worn or broken zif socket.
        The USB cable is frayed,connector pins worn or some other physical damage.
        Not enough amperage or voltage to power the programmer properly.
        Bad...
        09-02-2021, 04:40 PM
      • chonkyrabbit
        Need help disassembling xx30 thinkpad battery BMS chip firmware
        by chonkyrabbit
        Hi there,
        I need some help reverse engineering a BMS chip from a battery for an xx30 thinkpad. The Laptop uses a challenge-response type of system to verify if a battery is genuine:
        The laptop writes four bytes to 0x3C and then reads 0x3C. The battery responds with "Lenovo JapanXXXX", with the Xs corresponding to four response bytes. For example "0xDC 0x42 0x5B 0x82" to BMS => "Lenovo Japan0x9F 0x76 0x97 0x2E" from BMS.
        What I know so far:
        • It's an 51F51 BMS chip based on the R2J24020F group. Karosium has already figured out how to dump
        01-21-2026, 10:32 AM
