Diode "ZL9528" where can I find some
    • Jul 2011
    • 6059
    I Google this part # with no luck
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Diode "ZL9528" where can I find some
    When you can't find it, it helps to give us context.
    1) A picture helps.
    2) Where is it in the circuit board?
    3) What is the piece of equipment?
    4) Is there a schematic available?
    --- begin sig file ---
    --- end sig file ---
      • Jul 2011
      • 6059
      Originally posted by retiredcaps
      1) A picture helps.
      Will post later
      Controller board output to motor after the 2N6403 pair
      Motor speed control for a track welder
      N/A at this time
      • PeteS in CA
        • Aug 2005
        • 3581
        • USA, Unsure of Planet
        Depending on the age of the product, "9528" could be a datecode - 28th week of 1995.
        PeteS in CA
          • Jul 2011
          • 6059
          Thank for the info
          I will have to remove them from the board and see if there are any other # on it
          • ben7
            Capaholic
            • Jan 2011
            • 4059
            Hm, this seems more like a marking number for the part on the board, (I.E. "C1", or "R3") rather than the ID of the actual part. What package is it in? (D0-201, D0-41, etc..)
            Muh-soggy-knee
            • PeteS in CA
              • Aug 2005
              • 3581
              sam, a 2N6403 is an SCR, suggesting that what you are working on is mature technology, if not also some 15 or 20 years old. Industrial equipment is often expected to have a life measured in decades, so I'm not being critical. One hint as to the age of what you are working on (and to whether "9528" might a datecode) is whether the 2N6403 was made by Motorola or On Semiconductor (which was spun off from Mot in 1999). You may also find datecodes ("YYWW" or "WWYY" are common formats) on the PCB, electrolytic caps, ICs or large discrete semiconductors (e.g. TO-3, TO-220, and TO-3P or TO-247 packages). Some equipment even includes a date code in the serial number (e.g. Transistor Devices electronic loads).
              Speaking of packages, is the device in question in a large high current package? Or a low current package. If it's the former, the 16A, 400V current and voltage ratings may be a clue to suitable equivalent parts. Also, SCRs are not fast switching, like MOSFETs. So a >/= 16A, 400V fast recovery (100-200nS recovery time, not a 20-50nS ultra-fast type) rectifier in the same package and pin-out might work.
              PeteS in CA
                • Jul 2011
                • 6059
                It was made by Motorola
