Meter for my solar panel
  • JonathanAnon
    • Jul 2012
    • 457
    • Ireland
    Re: Meter for my solar panel
    Next addition: A light would be of practical use. So I have got my hands on a few 12V 35W MR16 bulbs. So this will be a proper load ~3amps from the battery, and a bit of renewable energy light for my computer room. I also built a 12V guitar amp, based on a LM386, and I can power this from the battery as well. So two practical additions.
    A kettle would be really handy, but I've read that 12v kettles are not really any good and require wires as thick as your arm for the current required to get the same power to the kettle... The single battery would not be able to supply that sort of power anyway. I wonder is there any sort of small 12v heating element I could get for defrosting food.. That would be handy.
    Was also thinking of maybe wiring up a few 12v plugboard and then put proper plugs on my 12V devices, instead of messing around with bullet connections. Bit worried about maybe somebody plugging in a 12V device in to the mains though..
    • howardc64
      LG 49UJ6500 LCD panel lighter band that goes away
      by howardc64
      49UJ6500 LCD panel has a lighter band on top when first powered on. Goes away (or gets much fainter) after TV on for a few min. After powered off for awhile and power back on, same band appears. If powered on immediately after powering off, no or much fainter band. Running the latest firmware.
      Disassembled the TV and lifted the LCD panel during testing. Band is on the LCD panel (can see the band on the panel as I lift it slightly) Backlight is perfectly even at the top edge. Double checked LCD panel alignment in the frame and is perfect but since band moved with the panel, its on...
      02-19-2023, 12:13 AM
    • triplefour
      SAMSUNG UN50TU8000F rebooting, backlight ok. No 12v to panel boards.
      by triplefour
      TV flashes backlight then reboots over and over. no image. Client said it used to have image for a bit before rebooting. Got worse over time.
      tcon is built into mainboard.
      Only one cable goes to panel boards.
      there is a cable from one panel board to the other that links them.
      cost cutting measure that results in us having harder time to diagnose.
      removing the link to the second panel board allows TV to stay on with stable backlight but no image.
      used cut off tape method to mask 1 maybe 2 pins on the side of the cable that goes to that second panel board....
      07-28-2022, 07:59 PM
      Ring Doorbell Solar Panel Battery Pack Modified
      I bought a Ring Doorbell 2 during Black Friday sale for my drive way but there is no wall outlet near unless I drill a hole in wall
      So I did a google search and found they have a non vendor solar panel and a battery pack but the reviews all said the same thing about about the solar panel connector going to the battery pack that it is easily broken because it is made on plastic circuit board which is very thin the battery pack is a hole another story in it self
      The batteries are a non brand battery that I have never heard of but the battery case was done very nice in...
      12-09-2019, 05:02 AM
    • Storyteller12
      QN55Q60R Service Menu Panel Help
      by Storyteller12
      I had a the above tv qn55q60r that had a bad panel but everything else good. I had another panel here from un55nu6900 with bad leds and melted diffusers.
      I put the nu6900 panel in and powered it up and it does work but there are lines vertical lines.
      I was trying to change the panel type in the service menu but don’t see my exact panel. Anyway to fix this or someone have similar experience.
      the clear picture is the panel type from the service menus on the nu6900. The other 1 is the panel type that was set for the q60r with the bad panel....
      01-13-2024, 01:57 PM
    • maneatingmonkey
      Missing LCD Panel Voltages VGH, VGL, VCOM (TCL 55P6US Sound & Backlight but NO Picture)
      by maneatingmonkey
      I have a TCL 55P6US with sound and backlight but no picture. This model does not have a T-CON board, and the right (rear perspective) panel board is fed from the left panel board. I have not been able to induce any change by disconnecting the secondary panel board or the tape cut-off method on the primary board.
      There are a bunch of voltages missing on the panel boards. I can't find any shorted caps of the panel boards, and all of the missing voltage rails read in the kiloohms, which leads me to suspect the issue may lie on the circuit board, rather than a short in the panel.
      03-27-2024, 07:17 AM
