Heres a good one, anyone know what surge (in amps) can be expected on a very low impedance low reactance load using 10000 uf 450 volt caps seriesed versus 6000 uf 450 volt caps seriesed with supply voltage of 300 vdc? The caps have fairly low ESR and low ESL but I have no way of checking
Cap surge current
Re: Cap surge current
Here is a sch of caps and they are actually parallel my bad https://www.badcaps.net/forum/attach...3&d=1364173402Comment
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by GraphicManHello
this is a rio volt portable mp3 cd player main board
accidentally its 120ac power adapter was used with 220ac
the unit worked for few seconds and then off and never worked again
it normally takes 3volts batts or 4.5dc from the adapter socket
in the picture I believe this is the main power IC (4 channels)
it is the only area in the board that barely gets warm after few minutes
drawing 0.4 watts in total continuously
i did checked all the caps on the board including these caps around the IC
nothing is shorted...-
by eryjusHello,
by sam_sam_samI have a battery operated tab welder and the battery does not have enough current for the battery tab welder because after about 30 welded it does not have the same current output it voltage has gone down by at least 0.500 volts or maybe a more than that
I can fit 21700 battery cells in the enclosure it is very tight fit for four of them that are 35 amp high current capacity 35X4=140 high current output this should work a lot better than what is installed right now
I tested the battery cells there are installed right now and they are testing good with no issues that I... -
by Paxman_SwedeHello!
I have studied the board and...-
- Loading...
