Arduino starter kit
  • ryan74
    • Oct 2012
    • 471
    • usa
    Arduino starter kit
    I want to get a breadboard to build circuits for fun and was thinking about getting a starter kit from arduino.
    http://www.arduino.cc/
    What do you guys think?
    Other suggestions?
    I'm pretty new to electronics and circuits but I have managed to fix or diagnose over 20 lcd tv problems.
    Sorry if I posted in the wrong spot.
  • Mad_Professor
    A Mech Warrior
    • Feb 2011
    • 1587
    Re: Arduino starter kit
    when I was building my arduino fan controller, I built my own arduino more like hackduino. I got atmega168 chip and the needed components like voltage regulator and decoupling caps with an inductor,
    *I didn't need the oscillator since the onboard 8mhz did fine for my application* and a basic electronic breadboard *you know these things http://itp.nyu.edu/physcomp/uploads/breadboard.jpg * , then I did the Parallel Port Programmer method.
    Actually I just used a male to female extension cable and cut some cat-6 wire and just strip and shove them in the female end and then wrap those to resistors then plug them into the breadboard, actually to the pin outs of the atmega chip, I didn't feel like splicing.
    I then wrote the code in arduino then used avrdude to upload it to the chip bypassing the need for a bootloader and USB/serial ISP port.
    It worked out well for 6 months and then I end up upgrading the server that this fan controller was being used in.
    Depending on what you need it to do you might have to set the fuses, I didn't, the stock settings were ok for me.
    Here are some links
    http://upvector.com/atmega/
    http://arduino.cc/en/Main/Standalone
    http://www.ladyada.net/learn/avr/avrdude.html
    http://www.arduino.cc/en/Hacking/Par...llelProgrammer
    If you need the hex for setting fuses through avrdude.
    http://www.engbedded.com/fusecalc/
    Hope this helps.
    • mariushm
      • May 2011
      • 3799
      An arduino is a quick and fast way to do something, but it hides a few things from you and simplifies others.
      If you want to actually learn something, it's more useful to get the the chips themselves and a programmer (plenty third party usb or serial programmers that are cheap) and do your own programming.
      I actually got myself a PICkit 3 with a demo board for around 60$ - it's a kit Microchip sells - precisely because I didn't want to be a sheep succumbing to using ready made code for arduino and because PIC chips are generally more readily available at distributors.
      PIC chips are a different architecture than Atmega (MIPS on PICs, AVR on Atmel) and the chips in Arduino, can be let's say 90-95% as fast (depending on what chip you use) and feature wise some PIC chips have more features than AT* ones.
      And they're easy to initialize from C code, to write c only (or inline asm), the datasheets are very detailed so no problem using them etc
      Once I have more experience with programming microncontrollers, I plan on just jumping to ARM based microcontrollers - these are faster, have generally open source compilers (gcc) but can be a bit more difficult to set up a development environment for (configuring gcc, linkers, setting them up in open source IDEs like eclipse etc), they need more initialization code so more work to start them, and they're generally not available in through hole/breadboard formats so you have to get either adapters or make your own tiny pcbs on which you solder them during development.
      • ryan74
        • Oct 2012
        • 471
        • usa
        If you want to actually learn something, it's more useful to get the the chips themselves, a programmer and do your own programming.
        -I do want to learn something(part of why I wanted something like this).
        Maybe theres a better educational electronics kit someone knows of but I dont want a kit meant for kids unless it is good. Something for beginner to moderate exp..
        -I understand how some components(caps,resistors, fets) work but not all.
        I have a partial knowledge of components and testing them.
        No knowledge of theory really.
        Iam better at learning while doing(hands on)
        -Im also looking at books but what I find are too advanced or meant for little kids.
        I wish I knew the book we used in high school, it had simple explanations/diagrams, written tests per chapter, and lab instructions. It was a great book for learning. It covered everything from what a fuse does to basic programming and theory.
        Unfortunatly I don't remember much from 20 yrs ago and it is a little harder to remember things I learn now due to age and mostly my past drug addiction when I was younger so a college/advanced book might be too difficult to start with.
        • ugamazing
          Best place to source RAM chips? 8GB 820-00850 boards to 16GB or 32GB
          by ugamazing
          I'm looking to upgrade several 8GB 820-00850 boards to 16GB or 32GB for personal use. I am curious what the best practice and process is for sourcing new replacement chips, and what vendor(s) you guys prefer? Another question is, how do I find compatible chips and their corresponding part/model numbers? For example, in the 820-00850 schematic, the DDR chip U2600 model listed (EDFB232A1MA) corresponds to 1x32GB chip. Of course, I would need 4x8GB chips to replace the 4x2GB chips currently on the board. How do I find compatible 8GB chips? Is it as simple as searching "BGA178 8GB 2133"...
          08-31-2022, 07:34 AM
          Acer TravelMate P214-52-566U+STARTER KIT 15'' Notebook P2 Specification for Upgrade or Repair
          This specification for the Acer TravelMate P214-52-566U+STARTER KIT 15'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P214-52-566U+STARTER KIT 15'' boardview and P214-52-566U+STARTER KIT 15'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
          09-06-2024, 07:20 PM
          Acer TravelMate P215-52-56G5+STARTER KIT 15'' Notebook P2 Specification for Upgrade or Repair
          This specification for the Acer TravelMate P215-52-56G5+STARTER KIT 15'' Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P215-52-56G5+STARTER KIT 15'' boardview and P215-52-56G5+STARTER KIT 15'' schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
        • feherhollo
          WSON8 NEW Bios Chips READ, ERROR, ETC.
          by feherhollo
          I asking for help on some new WSON8 256MB chips. Please share your experience. I faced error on some new chips on read, erase, write with different programmers. These new chips are not exist in any programmers database. (GD25B256D, XM25RH256, W25Q256JV so on.)
          I'm using RT809F V.5.0, EZP2023 Pro, CH341A Green
          For the exact experience with GD25B256DYIG is RT809F erase the chip under 33sec. This kind of 256MB chip normal erase time is 70-120sec so I think not all the partitions are erased. If I do blank check or reread the buffer says FFFFFF but when I write the correct...
          11-26-2023, 09:33 AM
        • Prott
          [RoG Ally] Fault in one of the onboard RAM chips. Any way to diagnose which?
          by Prott
          Hello dear badcappers!
          The title pretty much says it all - do you, please, know if there's any way to troubleshoot which of the integrated RAM chips (LPDDR5X in this case) is faulty?
          Backstory:
          After replacing the 4 onboard (soldered) memory chips on a RoG Ally (4x4 GB to 4x8 GB) it got stuck on the RoG logo. I assume one of the chips is either not soldered properly or faulty. However after reflowing and replacing bunch of them I am still stuck at the same place.
          If there is a way to narrow down which memory module is faulty it would make my life much...
          06-03-2024, 12:05 PM
