Guys,
I'm building a servo-loop to control my laser. Should I go SMT or not? How many PCB layers should I use? I have never designed an SMT PCB before, so I hope some of you folks can help me out.
It is a fairly simple ckt which consists of an input buffer, Integrator and a LPF (Butterworth 2 pole) (all have tunable time constants) and an output buffer. So, I' looking at about 4 IC's max, a few capacitors, resistors and 4 multi-turn pots. I'm worried that the advantages of minaturization will be lost because the POT leads would have to be soldered on to the board.
Input signal is low freq < 1kHz.
The o/p will couple to a HV amplifer.
The only thing I'm worried about is the mess it would make for me to replace the components, especially if the traces are too close.
