Sharper image evsi-htr70 space heater fixed!
  • cadillacman
    • Feb 2011
    • 524
    Heres something cool. I check the local business dumpsters from time to time and i come across this gem. Customer returned, still in the box.
    Its a sharper image ceramic tower fan/heater.
    I take her home, and it works but after about a minuite it shuts down. It has two 12vdc fans inside and only one works. I assume its overheating due to one fan not working and protecting itself.
    Without power the dead fan spins fine but with power applied it almost locks up. Then i noticed it.... the blade is up too high. These fan motors are brushless, theres a round permanent magnet attached to a cup on the fan blade. For whatever reason this one came from the factory not pressed in all the way. I simply removed the fan and cup assy, looked it over, then pressed it together until it clicked firmly together. Reinstalled it, i now have a $80 heater for free!
  • dfear
    ASUS Vivobook X1500e - no image and no backlight. Can this be fixed?
    by dfear
    ASUS Vivobook X1500e came in with no image and no backlight.
    Motherboard is: x415ea.
    Current knowledge/observations:
    RAM, LCD & LID sensor = oood.
    LCD connector - AC_BAT_SYS_ is present.
    D4501 schottky diode - LCD_BACKOFF# is always 3.3V, whether the lid is closed or not.
    CPU thermal signature seems normal.
    Laptop boots and outputs to HDMI.
    Is part of the CPU bad or can this be fixed?
    10-14-2025, 04:02 AM
    HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
    This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
    09-12-2024, 02:20 PM
  • Jaime Morillo
    Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
    by Jaime Morillo
    Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
    The TV was stuck on the logo and I couldn't access the update menu.
    I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
    The image result was good, but the image is inverted.
    The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
    Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
    08-18-2025, 11:38 AM
    Huawei MateBook MATEBOOK 16 SPACE GRAY Notebook 16 Specification for Upgrade or Repair
    This specification for the Huawei MateBook MATEBOOK 16 SPACE GRAY Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the MATEBOOK 16 SPACE GRAY boardview and MATEBOOK 16 SPACE GRAY schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...
    09-07-2024, 05:20 AM
  • edugimeno
    Vaillant 242 Gas Water heater. Shortcut in board anc compatibility with model 282
    by edugimeno
    Hi!!
    Yesterday I was installing a new Wifi thermostat for my domestic gas water heater model Vaillant 242/2-3, and accidentlly one wire from mains touched one wire from the thermostat output contacts. This shut off the heater so I finished installing the thermostat and then went out to check the heater
    I found one fuse blown (T2 250V). Replaced it with another equivalent fuse and it blew right away. I measured L-N in mains input and I sometimes got 4K but sometimes, not sure why, I got 100 Ohm...
    At a certain point, moving stuff around, I put all wires back in place and...
    03-24-2024, 02:31 PM
