How far off value do you let a cap go?
  • Hemingray
    KABOOM!
    • Jul 2010
    • 143
    Simple thoughts here, how far off of a cap's marked value do you let a cap get to before considering replacement?
    Me, I let it go no more than 50-55uF below value. Example is a 25" Magnavox TV/DVD/VCR combo unit that was handed to me for repairs, with a squealing power supply and no life. So far, found three caps that I considered useless:
    Cap 1: 1000uF/16V - Tested out at 799uF
    Cap 2: 1000uF/16V - Tested out at 843uF
    Cap 3: 2200uF/6.3V - Tested out at 1730uF
  • trebo
    • 514
    • Wales, UK
    Re: How far off value do you let a cap go?
    Caps have a tollerance code printed on them as in (M) = 20%
    Best to keep within the caps tollerance or considerably less, I would have thought, should be safe enough
    • retiredcaps
      • Apr 2010
      • 9271
      If the caps are in the SMPS/PSU side, then measuring ESR is required to see if they are within spec in addition to capacitance.
      --- begin sig file ---
      --- end sig file ---
      • Behemot
        • 4845
        • CZ
        Trying to not use them under 70 % of specified value.
