It's too big...
  • eccerr0r
    Solder Sloth
    • Nov 2012
    • 8695
    It's too big...
    (That's what she said...)
    You removed the old capacitor and bought a new one and later realize, it's too big to fit in the space of the old cap... So you make an extension or use the wire on the cap to reach the holes in the board.
    Well, ideally capacitor wires need to be as short as possible to reduce resistance. Yes, the excess leads will add to ESR and ESL (inductance) too... both of which are bad.
    But how bad is it if you just can't fit that capacitor into the space that was there (like trying to use a 12mm cap where the original was 8mm) and connected extension wires (as short as possible)... Anyone tried this and scoped out how bad the resultant waveform is? And even left it as it is?
  • shovenose
    Send Doge Memes
    • Aug 2010
    • 6575
    Re: It's too big...
    I've done it, never had a problem. I have tried it in PSUs only and not in something sensitive like a mobo though.
    • eccerr0r
      Solder Sloth
      • Nov 2012
      • 8695
      Re: It's too big...
      I'd imagine both motherboard and PSU have similar problems with ESR/ESL...
      I ended up doing the "long legs" on my Antec SP400 along with an undersized capacitor (with better ESR than the broken Fuhjyyu's) and though it works I never scoped out how bad the signal was... I better check...
      (the pi filter was source - 1mF (8mm) - inductor - 1mF (8mm)- output, and due to space and available parts it ended up being source - 1mF (12mm diameter, 20mm off the board using the leads that came on the capacitor when new) - inductor - 470uF (8mm, salvaged from something else) - output -- this is very bad -- but it'll have to do until I get proper sized parts, both in capacitance and physical size...
      It works though
      • turbozutek
        • Jan 2009
        • 71
        Re: It's too big...
        When I was young and didn't know any better I repaired some motherboards (early P4) with the capacitors standing over 3cm proud from the motherboard. I couldn't get a soldered on heat-sink off the back, so had to solder from above and access meant the caps sprouted out like mushrooms from the board.
        Worked perfectly for many years, but I guess it's all down to the design of the board and your luck!!
        Chris...
          Lenovo ThinkPad T490s + Ethernet Extension Adapter Gen 2 Notebook T Specification for Upgrade or Repair
          This specification for the Lenovo ThinkPad T490s + Ethernet Extension Adapter Gen 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the T490s + Ethernet Extension Adapter Gen 2 boardview and T490s + Ethernet Extension Adapter Gen 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum....
          09-06-2024, 08:58 AM
        • Dannyx
          Wire twisting tool for small wires - ideas ?
          by Dannyx
          Good day folks. Recently, I started doing more and more alarm system installs which involve dealing with a ton of small wires which are part of 4 to 12 core alarm cable. To make my installs as clean and neat as possible, I twist together the individual wires whenever possible to make braids like in the picture. It takes a lot of time and wears on my fingers really quickly, to the point where I actually developed a blister on my index finger from all the twisting. This got me thinking if there's a tool designed to braid small wires like this. I know there is something for twisting together solid...
          08-23-2020, 06:29 AM
        • ChaosLegionnaire
          correct way to connect bare speaker wires into spring clip terminals?
          by ChaosLegionnaire
          i recently bought a logitech z607 surround system. however, its giving me grief. when i first connected it, it only had sound coming from the front right speaker. after a great deal of fiddling and reseating the speaker wires into the spring clip terminals, i finally had sound coming from all 5 satellite speakers.
          however, the sound still gets cut off intermittently if i move the speakers, subwoofer or move/touch the speaker wires on the back of the subwoofer. so i wanna ask what is the right way to connect bare speaker wires into spring clip terminals?
          i googled...
          10-27-2022, 06:19 AM
        • budwich
          Headphone wires.... confused!
          by budwich
          I picked up a "beat up" set of sennheiser headphones (hd201). The phono plug end seemed to have an issue such that most of the time only one ear would work but by compressing / bending the jacket of the phono plug, I could cause the other ear to work. Must be a phono jack (3 pin) problem. So I cut it off and have solder based replacement. BUT... the wiring seems "mysterious" to me. I can't see how this can work or even ever worked. Attached is a picture of the wires (less the phono plug). One sheath has what I believe is two enameled wires while the other has basically...
          09-01-2023, 07:27 AM
