How to Pick the Right Capacitor
+ More Options
Posts
  • King Mouse
    • Sep 2012
    I am trying to repair my Dell 1908WFPf monitor. It seems to have three bad capacitors. The markings on them are as follows:
    CapXon
    GF 105 C
    Vent
    680 uF 25v
    I cannot find this exact capacitor and would like to know what might be a suitable replacement.
    Thank you,
    David
  • retiredcaps
    • Apr 2010
    • 9271
    Re: How to Pick the Right Capacitor
    My standard answer including examples on how to order, choose, etc (regulars may skip)
    https://www.badcaps.net/forum/showpo...84&postcount=3
    --- begin sig file ---
    --- end sig file ---
    • mockingbird
      • Dec 2008
      • 5484
      The datasheet lists it as follows:
      10 x 20mm
      1280 Ripple
      0.052 ESR
      Assuming the diameter on the datasheet matches the diameter of your cap, this is a good replacement and even exceeds the rating of the Capxon cap:
      https://www.badcaps.net/store/produc...roducts_id=144
      But like retiredcaps said, you really should replace ALL the caps, except for the large input cap.
      • King Mouse
        • Sep 2012
        Mockingbird,
        Thanks for your help! I ordered the caps you recommended and installed them. My monitor has come back to life!
        Thanks!
        Dave
        • Prolog
          by Prolog
          12-01-2024, 08:27 PM
        • chth96
          by chth96
          12-22-2023, 04:34 AM
        • chth96
          by chth96
          06-02-2024, 07:31 PM
        • chth96
          Is it no harm to replace with capacitor without ripple current rating?
          by chth96
          When I tried to repair LG 29 inch CRT TV, I found that the ESR value of samyoung SMS capacitor(160v 2.2uf), which is very close to D1879 transistor, is 6 ohm.
          Judging from above ESR Meter Table,I think It is necessary to replace this sms capacitor.So I visited local electronics shop,and I purchased 160v 2.2uf rubycon YK capacitor.
          But when I browse through rubycon YK datasheet,I found that there is no ripple current rating for 160v 2.2uf specification. But On the contrary, I found 39 mA ripple current rating for 160v 2.2uf SMS capacitor.
          Rubycon YK DataSheet (b...
          04-19-2024, 05:19 AM
        • chth96
          Should I replace polymer capacitor?
          by chth96
          a few days ago I finally purchased mser-100 v2 and I tested its abillity of measuring ESR value.
          I found that It shows pretty accurate ESR value for electrolytic capacitor,But When I measure polymer capacitor of dreamcast game console,I found that one third of polymer capacitor's ESR value is more than twice the value of ESR meter table.(for example, I measured one polymer capacitor of 6.3v 100uf, It showed ESR value of 7.68)
          Although my dreamcast now turns 20 years old but it still works. I occasionally have played game with it.
          Is this ESR value of polymer capacitor correct?...
          11-18-2022, 04:22 AM
