Gassy fluorescent tubes
  • japlytic
    • Oct 2005
    • 2086
    A few days ago, a fluorescent tube in an emgergency light fixture would not start properly, and replacing the tube fixed this problem. Trying the original tube in another fixture produced a similar result.
    There was a moderately strong purple glow at the ends of the original tube when it would not illuminate properly, indicating it was gassy. Is this true?
  • kc8adu
    • Nov 2003
    • 8832
    • U.S.A!
    Re: Gassy fluorescent tubes
    the cathode coating is worn out.typical eol.
    • davmax
      • Dec 2005
      • 899
      Flourscent tubes are normally filled with gas, electrons discharged down the tube excite the gas and ultra violet is emitted this in turn causes the coating on the glass to flouresce and produce visible light. So the tube is normally gassy. Failure is normally caused by lack of electron discharge, this is usually started by heating a filament at each end so that electrons are emitted. i.e the filaments fail. The filaments only receive power before the electron discharge starts. Once the discharge (arc) is established it causes a low voltage drop across the tube that bypasses the energy going to the filaments. The discharge current is limited by a choke, therefore most of the supply voltage appears across the choke.i.e the discharge is a low impedance.
      160Gb WD SATAII Server grade
      Nvidia 8500GT 256Mb
      Samsung 18x DVD writer
      33 way card reader
      Windows XP Pro SP3
      17" Benq FP737s LCD monitor
      • PedroDaGr8
        • Oct 2006
        • 130
        A bit more explanation on fluorescent tubes.
        The gas in Fluorescent tubes is Hg vapour (mercury) it emits strongly in the ultraviolet region. This UV light strikes a white powder photophor. This phosphor is what actually lights up (usually via fluorescence and phosphorescence). Most bulbs die because the emission mixture of gas in the bulb is used up via various reactions. Once the mix is used up the bulbs have a hard time maintaining the transmission. Older lamps used to use Ca5(PO4)3(F,Cl):Sb3+,Mn2+) which emit mainly yellow and bluw wavelengths of light (which look white to the eye but result in an incomplete spectrum for reflected colors, hince colors that originally match in incadescents dont match anymore), newer bulbs use additional phosphors with Europium and Terbium in them to generate a more complete spectrum.
        Note: unlike incadescent lightbulbs which generate a continuous spectrum, all flourescents and LEDs emit spectrums with peaks that our eye blends. Just look at them through a polarized grating and you will see what I mean.
        • DCJack
          B&K 707 tube tester. I need help.
          by DCJack
          Hi everyone!
          I managed to get my hands on a rough condition B&K 707 for "the best price" because it was not working. It's my first tube tester and I'm really wanting to get it up and running. I downloaded that manual that has the schematics and tested every resistor and capacitor and replaced the ones that failed. I replaced the missing 83 rectifier tube with a used but tested-good one. I also have a number 80 rectifier tube that I have used in tests before I found the 83 tube.
          Initially I noticed that I was not getting the red on-light to turn on, but it...
          03-05-2024, 05:05 PM
        • edugimeno
          "First Experience" with a CFL BL Samsung TV
          by edugimeno
          Hi There!
          I just wanted to share experiences trying to fix for the first time a CFL backlight Tv. It is samsung LE32A336J1N
          The issue it was showing was: As soon as I turned it on, the BL would turn on/off for 2-4 times and them off definitely
          I suspected the BL voltage generator or the LED strips, at least until I opened it up, cause I had never seen these TV's
          When I opened it I found a very robust TV with a complex chassis formed by mutiple arms tied together with screws. There was a large PS board with several transformers for backlight,...
          05-28-2023, 03:41 PM
          Light that has a bug zapper in bottom section of light fixture the LED light module took a crap but the zapper still works
          So I got the bright idea to remove the LED light module from the fixture and put it on top of another enclosure and keep using the zapper
          The removal of light module was a successful and now I just have to cut a hole in the enclosure and put a power cord that has an on and off switch on it
          You are lucky to get about two years of service out of one before the LED module starts flicking and just stops working because it is mounted on an aluminum plate and these are hard to solder on it and it is not worth messing around with them and especially this one because it has line...
          09-07-2024, 07:26 PM
          LED Solar Flood Light Dusk to Dawn Security Wall Street Yard Outdoor Lamp modifications are in order
          I bought one about a month ago from an eBay seller who now is out of stock however I found another eBay seller that has the same version of this device so I think about buying a few more of over a period of time
          Awhile back I bought some A123 brand 18650 battery cells that are 3.2 volt battery cells that I am going to use in this device for more running time in a florescent bulb fixture that I gutting out the tube sockets and turn it into a solar powered LED lighting fixture instead
          Pictures will come later when I have the lighting fixture gutted and have the battery...
          08-11-2024, 11:10 AM
          Lithonia Lighting versus Light of America Compact Fluorescent product quality
          I have a Lithonia Lighting 65-Watt Gray Hardwired Compact Fluorescent
          I also have back when Light of America had these light bulbs available for yard lights
          The issue with Light of America was the blast boards had all most certain board failure while bulbs hardly ever fail
          While the Lithonia lighting fixture has all most certain bulb failure
          So I have modified the Lithonia lighting fixture to accept the Light of America light bulb and see how long this will last
          I have only had this light fixture for not more than a year if it...
          07-02-2023, 03:45 PM
