Other devices using popular Nokia battery models
+ More Options
Posts
  • japlytic
    • Oct 2005
    • 2086
    I have seen other devices, including a Bluetooth GPS receiver and a wireless keyboard/mouse combo, as well as other devices which use popular Nokia battery models.
    It could be a safe bet that you can still get such batteries for quite a while.
  • b700029
    Banned
    • Sep 2010
    • 640
    Re: Other devices using popular Nokia battery models
    Probably not Nokia originals though, but it does seem that formfactor has become a sort of de-facto standard for various Chinese electronics.
      Nokia C2-01 RM-721 RM-722 Phone Schematic
      The Nokia C2-01 RM-721 RM-722 was a mobile phone produced by Nokia. The Nokia C2-01 supported 3G and had a 3.2 megapixel back camera. It had a single SIM card. The handset was introduced to the markets in 2011. It replaced its predecessor, the Nokia 2700 classic and Nokia 2730 classic and has improved specifications....
      11-05-2024, 07:40 AM
      Mounting and Handling Guidelines for TO220 TO220F TO247 Cases / Packages
      The TO220, TO220F and TO247 are the popular packages for power devices because of their versatility and ability to dissipate moderate amounts of heat. This application note describes the basic guidelines for handling power MOSFETs in TO220, TO220 and TO247 packages shown in Figure 1. Please note that only mechanical and soldering guidelines are covered here. Additional precautions are required for isolating high voltage rated devices to meet safety regulations.
      Securing a good thermal interface between...
      10-07-2024, 04:35 AM
    • muhuruu
      PS5 too many USB devices connected
      by muhuruu
      Hello. I have a problem with a PS5 console that I bought to learn electronics repair. The auction description indicated that the console had been dropped. The HDMI port and USB ports were damaged. The HDMI port was replaced by the previous owner, and after his repair, the console worked for 2 days and then became dead. After receiving the console, I replaced all the USB ports. After replacing them, the console started to turn on. On the logo screen, it displays "too many USB devices connected". My further attempts to fix the error involved replacing the Southbridge, 4 TPS2001D chips,...
      05-19-2025, 07:14 AM
    • dqtech
      Lenovo Yoga 12 LA-A342P usb not detected but does charging devices
      by dqtech
      this laptop has been done by other tech...he did replace new usb port but problem still persist and early problem is both usb port not detected thumbdrive but it does charging device/phone...i need help to diagnos this problem
      here the link for schematic - https://www.badcaps.net/forum/troubl...42p-schematics...
      03-15-2025, 09:59 AM
      HP Clean VSS2 dumps,fix Endpoint Security error
      by SMDFlea
      Just a thread to post clean VSS2 files/dumps in.A clean VSS2 file can, in some cases, fix
      the infamous **"Endpoint Security" error message.
      Be aware that if you use a clean VSS2 you may need to fill in missing DMI info using HP BCU !
      I`ve included some clean files/dumps,offsets and a few scripts to autopatch a few models.
      The offsets and file sizes are part of the naming convention i`ve used for the extracted
      files.
      hoaca388 has made an excellent guide how to extract the VSS2 file and edit/clean it up by
      filling everything after...
      08-08-2024, 03:14 PM
