Who made these back in the day? Pulled a good number of them from a 1979 Toshiba 19" TV set that checked far below their values (One of the 22/160 caps barely even registered 1nF!). Some that I pulled, checked almost double their values.
Marcon caps
Re: Marcon caps
Marcon was the name of the company, and their quality was in the same class as UCC, Nichicon and Rubycon. Nippon Chemicon (NCC/UCC) bought Marcon some 20 years ago.PeteS in CA
by momakaI know I've been a little scarce lately (like the last 2-3 years), but I'm still here and still doing my thing with fixing PSUs.
https://www.badcaps.net/filedata/fetch?id=359177... -
by RutsHi
I managed to knock off two capacitors on a EDM 033 board near the southbridge and BIOS chip.
Does anyone know the values of these capacitors?
by briztechHi can anyone identify missing caps/values on Matebook D15 DAH98NMB8C0 REV C HF - Thanks
1 Photo -
by eryjusHello,
by Paxman_SwedeHello!
I have studied the board and...-
- Loading...
