I know how to check other components but IC's are always a pain in the a**. I don't have any expensive equipment to test it with, only a multimeter. Also I'd like to know how to test smd resistors and capacitors without desoldering them off the board. Any help is greatly appreciated.
How do I test integrated circuits with a multimeter?
Re: How do I test integrated circuits with a multimeter?
you can't with the resistors and caps... they have to be out of circuit to be tested (otherwise you are testing the whole circuit, which often has other devices in parallel, messing up thee test)
as for ICs, depends on the IC. get a bench PSU, a solderless breadboard, and breadboard wires and build a sample circuit as per the device datasheet.sigpic
(Insert witty quote here)
This is going to be a bit of an effort for me but will give both approaches a go and see which one works better. Thanks for the suggestion guys. If anyone else has any more ideas I would like to hear them.Guns don't solve problems. I'll take 12
There is no easy way to function test ICs except perhaps basic logic gates - of course you can check any IC for dead shorts, though.
Since they all have completely different designs and functions, the only real good test is in the circuit it was designed for, and verify by substitution.
Originally posted by Koda View PostAlso I'd like to know how to test smd resistors and capacitors without desoldering them off the board. Any help is greatly appreciated.
If in doubt, you still have to remove it and test out of circuit. There is no way around that."Tantalum for the brave, Solid Aluminium for the wise, Wet Electrolytic for the adventurous"
-David VanHorn
Originally posted by Koda View PostI hoped to avoid removing dozens of smd capacitors and resistors from boards to test them.
With a schematic you can check the value of the resistors and capacitors and use a 'not less / greater than' rule. A good resistor in circuit will never read greater than it's true value because parallel resistances will reduce the resistance. A good capacitor in circuit will never read less than it's rated capacitance because any parallel capacitances will increase the capacitance.
PlainBillFor a number of reasons, both health and personal, I will no longer be active on this board. Any PMs asking for assistance will be ignored.
