Schematics General Question
  • Peter9DO
    • Dec 2011
    • 277
    So, I know this might seem very basic, but for some reason I'm not getting the right answer on this and I don't know what I'm doing wrong.Now I know what the right answer is, however I can't seem to come up with it. Now, I'm not going to just tell you the answer (Muuu-hahaha). I want to see what you guys come up with, and I bet you come up with the same thing I've been coming up with.
    Here is the question:
    In the picture there are 3 resistors connected to a 12v battery. Assume that all component values are mathematically exact. How much current flows threw the 4.8-ohm resistor?
    Thanks guys!!!!!
  • kikkoman
    • Jul 2007
    • 691
    Re: Schematics General Question
    1 amp.
    parallel resistance of the 2 others is 7.2ohms, so total resistance is 12ohms.
    [U=R*I] gives you: ----> 1 amp <----.
    too hard?
    "Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin slitting throats." - H.L. Mencken
    • Peter9DO
      • Dec 2011
      • 277
      Ok, how did you get 7.2?
      • Peter9DO
        • Dec 2011
        • 277
        Nevermind.... I got it.... 12x18/(12+18)= 7.2 Ohms.
        • kikkoman
          • Jul 2007
          • 691
          the formula is 1/R(total) = 1/R1 + 1/R2 + ...etc
          • Peter9DO
            • Dec 2011
            • 277
            By the way thank you for the help! I was not using the proper formula for the parallel resistors. But again, thank you.
            I know it's simple, but I'm just starting to learn all of this now. In the past I have just swapped out parts and boards, or whatever that I need to change, I would like to be able to board level repairs. This is going to be a long learning process.
            • kikkoman
              • Jul 2007
              • 691
              don't despair!
              i know, it's mostly these basic things that are the hardest. if it's just as a hobby, 'learning by doing' is the way to go.
              here's a tool i can recommend for these little problems (saves a lot of paper):
              http://www.electronics2000.co.uk/download.php#assistant
              and eevblog.
              • Peter9DO
                • Dec 2011
                • 277
                Thank you! Well I would say, it's a little more than a hobbie. I really enjoy doing repairs on electronics and I have been able to supplement my income quite well by doing so. I've fallen into the habbit of just swapping out parts. The most I have done on a board level repair is some BGA reballs and swapping out bad caps. I would like to learn the rest of this good ol stuff to save me some money. Where I will be able to repair circuts opposed to replacing everything.
                I just want to be more proficient in this industry, that I admire so much. Thanks for the link and the help!
                • ben7
                  Capaholic
                  • Jan 2011
                  • 4059
                  Haha, yeah, simple things like this can be complicated. I always look back at things I am good at now, and I remember that they were hard at first.
                  Good luck!
                  -Ben
                  Muh-soggy-knee
                  • Peter9DO
                    • Dec 2011
                    • 277
                    Thanks Ben... I always say "if it was easy everyone would be doing it". I enjoy learning more especially when it's something I'm interested in and it makes me money. You really can't beat that!
                    • severach
                      • Aug 2007
                      • 1055
                      Set the circuit up and verify everything with a meter. The theoretical stuff is easier to understand after watching it work live forces you to discard your disbeliefs.
                      sig files are for morons
                      • Peter9DO
                        • Dec 2011
                        • 277
                        I have done more in the past with the hardware but I just didn't understand why or how everything worked other than having a general idea of what was what on the board. I can't tell you enough how much I'm enjoying learning all the theroies behing it now. It really is easy math, however I was never very good at it. With the issue I was having with exersise was in the chapter the formula was in a tip instead of the generals reading. It also was listes as something that you don't use. But yet it was on the xhapter exam, I don't understand why the book set it up that way. Seeing this is the first chapter and I have a whole book to get threw, I'm sure I'll be asking more questions. I'm not doing any of this in school so when I have a question I don't have anyone to ask. Now, I see what a help you guys have been, I have the confidence any questions I might have in the future will be answered with no problem. Needless to say I'm sure I will be posting more. Again, thanks again everyone for all your willingness and your help! You guys are GREAT!
                        • Peter9DO
                          • Dec 2011
                          • 277
                          Originally posted by kikkoman
                          don't despair!
                          and eevblog.
                          I just downloaded this... This program is awesome! It packs everything into a single convenient program! I'm still going to learn to do it the long way but this is a nice little tool to have! Thanks again Kikkoman!!!!!
                          • PeteS in CA
                            • Aug 2005
                            • 3582
                            • USA, Unsure of Planet
                            Ditto what severach said! Be sure your experimentation includes a voltage divider that uses values in excess of 4 or 5 M-Ohm ... you may learn something about your meter. Another interesting version of that experiment would be to observe the charging of a capacitor through a 10 M-Ohm resistor using an oscilloscope.
                            It's good to be aware of the limitations and funnies of one's instruments. Try connecting your oscilloscope voltage probe tip to its ground lead, and then hold it near a P/S or VRM switch MOSFET (obviously, while powered on and active). If your vertical sensitivity is set to .5V or 1V per division and the trigger to .5V or 1V, you should see noise spikes from the switching of the device. Your ground lead is acting as an antenna. You can use that to detect whether a P/S or VRM is active. I use it at my present job to detect whether and approximately where arcing is happening (I currently work with P/Ss that produce voltages in the 1.5KV-10KV range). Another thing to remember is that oscilloscope voltage probes have 10pF-25pF from tip to ground. Sometimes that is enough to affect the signal you see (BTDTGTTS!).
                            PeteS in CA
                            • Popalwali
                              Asus Nexus 7 2012 (ME370T REV 2.4) Schematics needed
                              by Popalwali
                              Hello Everyone,
                              I will be really grateful if someone shares schematics and if possible the boardview of the old Asus Nexus 7 (2012) Tablet. The motherboard is ME370T Rev. 2.4. Now I can find schematics for the Rev. 1.0 but I could not find the schematics for the Rev 2.4. I tried to look for similarities in the Rev. 1 but there are somethings missing, plus the board i have has nearly no component names printed on it which as a newbie makes pretty hard for me to locate things. Any assistance will be appreciated. Thank you.
                              08-25-2024, 11:28 AM
                            • Techmanx
                              Schematics Download Site
                              by Techmanx
                              If anyone needs schematic diagrams for any pro audio gear like what professional musicians use, such as guitar amps, power amplifiers, vintage tube amps, musical gear like keyboards, effects pedals, guitar wiring diagrams and service manuals, check out https://schematics.ca . I'm a road musician and an electronics tech and I got schematics for just about every piece of gear in my band from this site and they are free to download. It's always good to be prepared in case you fry something while on on the road, which always happens it seems. https://schematics-free.com has a lot of free audio schematics...
                              06-28-2023, 12:08 PM
                            • Plg_666
                              Need schematics of Msi claw a1m
                              by Plg_666
                              Hello, comrades. I've encountered the following issue. I live in a small town, and we had a power outage. My girlfriend's MSI claw was unlucky because it was charging at the time and didn't turn on afterward. The local service center suggested replacing the Tps65993bh controller. However, after replacing it, the motherboard still didn't start. The technician believes that the processor might be dead, but he needs the motherboard's schematics to confirm this. Please share the motherboard schematics if you have one for this console or a laptop with a core ultra 5/7 125H/155h processor.
                              10-28-2025, 01:35 AM
                            • mrautom8
                              Samsung TV UN75H6350AFXZC main board schematics?
                              by mrautom8
                              Schematics for the main board needed please. Sticker on board states BN94-07517A but the silkscreen says BN41-02157B. Cant find here or anywhere on the web.
                              Backlights work when main boards disconnected. When connected and power button switched, the relay on the PSU board turns on for one second then back off.
                              While relay is on, all voltage rails are present and steady (scoped) on main board.
                              I love a good logic puzzle but getting lost without any schematics.
                              No shorts on ANY capacitor main board.
                              Thermal camera shows 3.3V inductor getting warm instantly but...
                              10-19-2025, 06:32 PM
                            • CG_Dionysos
                              MacBook Pro 15-Inch | Mid 2017 | A1707 | 820-00928-A | 3,1 GHz i7, Radeon Pro 560, 16GB, 1TB | Boardview and Schematics
                              by CG_Dionysos
                              I am looking for the boardview file and the matching schematics (PDF) for the following MacBook Pro:
                              • Model: A1707
                              • 15-inch, Mid 2017
                              • 3.1 GHz Core i7
                              • 16 GB RAM
                              • Radeon Pro 560
                              • 1 TB SSD
                              • Board number: 820-00928-A
                              I already searched the forum, but so far I haven’t found a matching boardview for this board. In several posts I came across, it was also mentioned that the uploaded files were often incorrect.
                              Thanks in advance!
                              Greetings from Germany...
                              09-16-2025, 06:43 AM
