Need help ID capacitor manufacturer.
  • Evil Lurker
    Warranty Voider
    • Feb 2011
    • 454
    Ok its a radial leaded little yellow dipped multilayer or monolithic cap, uses typical multiplier markings same as SMD resistors and inductors ie 104=0.1uf.
    Definately not a tantalum. Commonly found in computer PSUs on the secondary side. Comes in blue, but markings different. Usually has three letters below the number value, I have seen CSK, K5K KCS and a few others.
    Have no clue who the hell makes them... would like to find out to have a peek at the datasheet.
  • MORETTIGIAN
    by MORETTIGIAN
    Title:
    Description:
    Procedure performed:
    - Removed backplate
    - Reapplied thermal compound
    - Reassembled card
    09-18-2025, 12:14 PM
  • Prolog
    by Prolog
    12-01-2024, 08:27 PM
  • Agent24
    Dick Smith Q-1760 linear power supply filter capacitor question
    by Agent24
    I have acquired a used Dick Smith Q-1760 power supply - although the OEM is Manson Industrial
    It has at least one problem.
    The voltage control potentiometer VR2, 50K is faulty - going high resistance / open circuit in the CCW end and leading to the output voltage jumping around.
    I have already ordered a replacement potentiometer, so that's not an issue.
    Now, I want to replace all three electrolytics on the PCB as they are CapXon and I don't trust them so much, I will replace them with something better while I've got the thing apart anyway.
    All are CapXon...
    10-21-2025, 05:39 PM
  • chth96
    by chth96
    12-22-2023, 04:34 AM
  • chth96
    by chth96
    06-02-2024, 07:31 PM
