Is instant glue safe for use in electronics?
  • SeanB
    • Jun 2013
    • 41
    • South Africa
    Re: Is instant glue safe for use in electronics?
    I use a 2 part epoxy to hold heatsinks to chips. I prefer Pratley quickset steel, but you can use Araldite quickset white epoxy or pretty much any other 2 part epoxy as well. Clean both surfaces, then sand the heatsink and chip top lightly with 220 grit waterpaper and wipe both sides down afterwards with solvent ( acetone, IPA or even methylated spirits, then mix a little eopxy and apply a thin layer to one surface, then clamp the 2 together until cured. I tend to just mix a match head sized bead of each tube on the top of the chip in the middle with a paper clip, then place the heatsink on it and press down to spread it out to cover the chip. then place a small weight on top and leave for a half hour till cured past gel state. then you preferably leave for 24 hours or gently heat to 70c to hasten the cure. Generally you get a 30C drop in chip temperature, using a small heatsink with fins about 20mm tall covering the entire chip top. Common source of the heatsinks are old motherboards, taking the north bridge, south bridge and memory heatsinks.
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16956
      Originally posted by momaka
      That's what I am most afraid of.
      I have several motherboards that could benefit from some heatsinks on some of their MOSFETs... but I don't know what to glue down the heatsinks with. AS thermal adhesive is $15 for 7g - too much for fixing up an old motherboard that's probably not worth even that much.
      Wood glue seems like it will crack with the heat-cycles, thus causing the same problem you mentioned. I haven't tried it, though. (But I am pretty sure that is what's going to happen.)
      Hot glue melts at too low of a temperature and becomes quite gooey even at under 100C.
      Bathroom silicone releases acetic acid IIRC, so that's likely a no-go on heatsinks and electronics, I think.
      Guerrilla Glue? Anyone try that before?
      JB Weld. Done many that way.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
        master hoarder
        • May 2008
        • 12175
        • Bulgaria
        Sweet!
        $6 for 50 grams? I'll take that any day over the AS adhesive. Thanks for the suggestion.
        Originally posted by stj
        but what have you go in mind?
        most of the heatsinks you see on mobo fet are for looks.
        the resin package is a thermal insulator - your heatsink would need to go onto the tab.
        if you look where the fets are soldered, you will see a shitload of copper via's to the back of the board,
        and these go into big tracks.
        this is a form of heatsink embedding
        Right. But there are situations where either the copper planes on which the MOSFET is soldered to is too small or the heat dissipation by the MOSFET is just unrealistic for an embedded copper plane heatsink to take care of. I have the latter (stupid ASUS design on a AsRock motherboard), and the MOSFET's case temperature is anywhere between 70C and 80C depending on the room temperature. There are two caps next to it. They used to be small 8x12 mm OSTs and they would get cooked. I replaced them with tall 8x25 mm Panasonic FJ. They still get insanely hot, but the MOSFET is about 5C cooler on average. I think a large enough heatsink with decent thermal coupling to the MOSFET should help at least another 5C.
        • Behemot
          • 4845
          • CZ
          Does that JB Weld thing have high enough heat conductivity?
          I use akasa thermal pads lately, they are those soft types with adhesive on both sides, seems to work OK so far, I'll see in a few years if it is OK or not cooling insanely hot FETs in displays
          BTW check this improvisation of mine
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16956
            Yes, it does conduct quite well. See my old DVD266URN thread... Thanks to JB weld and some properly placed heatsinks, it brought a pretty much unusable board to perfectly stable.
            Now, I do like your improvisation there.....soldering washers to diodes and transistors. I'd have never thought of that. If theres just a little air moving, that would make a noticeable difference I'm sure.
            Team : 49813
            Join in!!
            Team Stats
              • 31067
              then maybe you could create some heatsinks with a stepped side on them that makes contact with the top of the tab.
              • Behemot
                • 4845
                • CZ
                #27
                It was the only thing I have come up for cooling these small TO-251 transistors, they are too small to atach any heatsink to them (I also did not have any glue or adhesive by that time). And as for diodes, only solution I have seen in old electronics was either using bigger diodes (which also have too thinck electrodes), or soldering them to something (also applied for TO-220 transistors, it was not that uncommon back in 90s). So I just soldered something to them
                Quite many displays, especially Samsung and LG, use some thin sheetmetal, as a heatsink. It is soldered few centimeters away from transistor, the heat is transfered from pad to copper layer on PCB and from there to those heatsinks. At some boards there are only the spots for them. Check for example http://diit.cz/clanek/lg-flatron-w22...ertorem-oprava
                  master hoarder
                  • May 2008
                  • 12175
                  • Bulgaria
                  #28
                  http://diit.cz/sites/default/files/chlazeni.jpeg
                  0.o that's ghetto mod territory right there! But I like it .
                  I did something similar on a Dell LCD monitor - I soldered a long piece of used desoldering braid to the pads of the transistors and bent them like a heatsink.
                  Here's another variation of that I did afterwards:
                  https://www.badcaps.net/forum/attach...5&d=1357084641
                  No space to solder to the tab - it's backed up against the memory slots.
                  • PeteS in CA
                    • Aug 2005
                    • 3581
                    • USA, Unsure of Planet
                    #29
                    Like the washers adaptation. The plating on the washers have to be solderable (e.g. tin-plated). A good variant might be to use solder/crimp ring lugs, which are tin-plated and available in a wide variety of sizes.
                    PeteS in CA
                      • 31067
                      go to a plumbing shop & get copper washers.
                      • Behemot
                        • 4845
                        • CZ
                        #31
                        No need for that, just use high-enough powerfull soldering iron and enough sodlering flux. I think these are native iron washers. Maybe nickel-plated but I don't think so.
                        • acedogblast
                          by acedogblast
                          11-02-2024, 05:13 PM
                        • mitsu2k
                          The Real Dangers of conductive glue.
                          by mitsu2k
                          I know many folks on this forum warn against conductive glue and suggest removing it immediately upon site. I'm here to vouch and say these people know what they are talking about. To be more accurate, the glue isn't intended to be and doesn't actually start out conductive. It gets conductive as it is heated by components that get hot. The glue starts out to be a light tan color but as it is exposed to heat, it gets darker and darker until it is a dark brown. I have found that it becomes conductive at the point that it reaches a light brown color on darker.
                          Here is an experience I...
                          04-16-2023, 06:29 PM
                          HP ProDesk 600 G5 + Aruba Instant On AP11D (RW) ProDesk 600 i7-9700 Specification for Upgrade or Repair
                          This specification for the HP ProDesk 600 G5 + Aruba Instant On AP11D (RW) can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + Aruba Instant On AP11D (RW) boardview and ProDesk 600 G5 + Aruba Instant On AP11D (RW) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                          09-12-2024, 02:30 PM
                          HP EliteBook 830 G6 + Aruba Instant On AP11D (RW) Notebook 800 Specification for Upgrade or Repair
                          This specification for the HP EliteBook 830 G6 + Aruba Instant On AP11D (RW) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 830 G6 + Aruba Instant On AP11D (RW) boardview and 830 G6 + Aruba Instant On AP11D (RW) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                          09-06-2024, 06:20 PM
                          HP ProBook 430 G7 + Aruba Instant On AP11D (RW) Notebook 400 Specification for Upgrade or Repair
                          This specification for the HP ProBook 430 G7 + Aruba Instant On AP11D (RW) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G7 + Aruba Instant On AP11D (RW) boardview and 430 G7 + Aruba Instant On AP11D (RW) schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
