I have a motherboard from a DELL XPS 700 desktop tower. This motherboards power supply connections can be seen here ---> http://support.dell.com/support/edoc....htm#wp1060771 This particular motherboard has 2 power supply connections. 1 being a standard 24 pin and the other a non-standard 20 Pin (gotta love Dell.) Could I use a standard power supply for the 20 pin if I rewired it and if so, how would I wire the 20 pin connection?
DELL XPS 700 Desktop PSU
Tags: None
Re: DELL XPS 700 Desktop PSU
Seems odd that a single socket motherboard needs two atx connections.
Looking at specs, you need a 1 KW PSU or 750W PSU. The pin layout on power1 are not the same as power2.
You could splice it doing a solder job or using wire taps/nuts, You have the pin lay outs on both, I don't see why not just use a high enough PSU like a 750 would do it.
Frankly I would just buy the proprietary PSU off ebay or google shopping or some where and when you get it, test it and then recap it. -
Thank You, I actually JUST found and bought the correct 1K Watt Dell psu from Ebay so disregard the original post. Thank you to all who read and much love!!!!
Assuming...7 Photos -
by sam_sam_samI have wanting to do this project for quite sometime now and I finally found a switching power supply that will work on this desoldering gun station ZD-915 that the original switching power supply took a shit and just was not worth trying to fix it because this switching power is not quite big enough to handle the heater element and the vacuum pump
One note when I tested the switching power supply and the voltage control board I noticed that this desoldering gun heat up much faster than the original switching power supply which I was really surprised by to the point that I might buy... -
by Info13Hi everyone,
A H235P-00 power supply unit from a Dell Optiplex 760 PC is faulty.
After removing it from the computer, I placed a paper clip between the green and black wires, then connected it unloaded to the mains through a series lamp.
➡️ First test:
The PSU partially works: the green indicator LED lights up, and the fan starts for one second, then stops.
A click can be heard at the moment it stops. The series lamp lights up when the power supply starts, then turns off when it shuts down.
I then followed the advice from the forum and replaced... -
Dell OptiPlex 390 Desktop Schematic & Board View
MIH61R (Dell OptiPlex 390)...-
Channel: Schematics and Boardviews
10-05-2024, 01:54 PM -
This specification for the HP Slim Desktop S01-pD0117d can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Slim Desktop S01-pD0117d boardview and Slim Desktop S01-pD0117d schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification,...09-12-2024, 03:28 PM
- Loading...
