Inverter Tester
  • sabre504
    • May 2010
    • 449
    Inverter Tester
    Hi was thinking of building an inverter tester and am just stuck on what sort of bulbs or led's i could use.
    I dont want to use long CCFL's but i know that the inverter puts out anywhere between 600v and a 1000v.
    Any suggestions welcome
  • Jack Crow
    It's a CLASOB!
    • May 2008
    • 823
    Re: Inverter Tester
    S,
    CFL lamps would be a bad selection.
    Normal lamps are getting rare.
    Inverters are a problem since most output square waves.
    Let's say you have a working unit on the bench and a strong enough power source.
    I presume you have a scope and a meter to make some open circuit tests.
    If all that looks good, your next step is to do a 'load test'.
    May I suggest an old toaster or electric room heater. Work out a combination of load circuits that will give you the rated loads.
    You might tray an Amp Clamp to measure output current, but it might not respond well due to the square wave action.
    Another load might be something as simple as a heavy soldering gun. One of the 300 watt types. A big step down transformer into a hard current load. All that inductance might get the amp clamp to read well.
    Another issue is source Z of your DC. Some power sources can't deal with a load like that. I killed an automotive alternator in my truck due to a vehicle inverter.
    If you can, post back here with what you find that works. Your situation can't be unique.
    Be well there.
    Jack Crow aka Radio Mike
    Herndon VA
    "You are, what you do, when it counts"
    The Masso
    "Gravity, the quickest way down"
    Mayor John Almafi
    "You ever drop an egg, and on the floor you see it break?
    You go and get a mop so you can clean up your mistake.
    But did you ever stop to ponder why we know it's true?
    If you drop a broken egg you will not get an egg that's new?"
    MC Hawking
    • sabre504
      • May 2010
      • 449
      Re: Inverter Tester
      Hi thanks for that interesting reading.
      But i was meaning a ccfl inverter tester sorry my fault should have made myself more clear on what i was asking.
      I keep forgetting that there are other resource to this site and i know i have only scratched the surface of the amount of available knowledge.
      Again thanks for your reply still wonder what i can use as a light for the test ,
      i have been told that i can fool the inverter into thinking there is a ccfl connected by using a 200k 5 watt resistor but could i attach a bulb to this in some way as a visual indicator
      • Jack Crow
        It's a CLASOB!
        • May 2008
        • 823
        Re: Inverter Tester
        Ok,
        Catching on.
        In my world when someone says inverter it's to take 12 volt auto up to usually 120vac to run home devices in the field.
        At that kind of voltage you may have to look at a string of resistors in series.
        Little things.
        Normal scope probes cannot be trusted at high voltage.
        Imagine if that much voltage has a flash over into your hand? Not cool.
        Same deal with coupling caps. You may have to think about external voltage dividers to take your ripple readings safely.
        I learned about this the hard way at the last job. We were working on some very high voltage devices and I had a three inch 100M ohm resistor flash over and fail. Very impressive just inches from the nose.
        If your only going to a Kv most 'consumer' DVM's can take that. Some can't. So watch your upper limits.
        Be well there.
        The Masso
        Mayor John Almafi
        MC Hawking
        • sabre504
          • May 2010
          • 449
          Re: Inverter Tester
          Thanks for the info
          • fuhrer
            • Dec 2010
            • 16
            Re: Inverter Tester
            you can use old ccfls..they will work fine..the only thing is, inverters have very sensitive error detection circuitry.need to buypass it..
            • fuhrer
              • Dec 2010
              • 16
              Re: Inverter Tester
              bypass i mean..sorry
                HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                09-12-2024, 02:20 PM
                HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook 1000 Specification for Upgrade or Repair
                This specification for the HP EliteBook 1050 G1 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 1050 G1 + Image Load & Asset Tag boardview and 1050 G1 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that...
                09-06-2024, 10:56 AM
                HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook 400 Specification for Upgrade or Repair
                This specification for the HP ProBook 450 G6 + Image Load, Asset Tag & Testntag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load, Asset Tag & Testntag boardview and 450 G6 + Image Load, Asset Tag & Testntag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps...
                HP ProBook 430 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                This specification for the HP ProBook 430 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 430 G6 + Image Load & Asset Tag boardview and 430 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
                HP ProBook 450 G6 + Image Load & Asset Tag Notebook 400 Specification for Upgrade or Repair
                This specification for the HP ProBook 450 G6 + Image Load & Asset Tag Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 450 G6 + Image Load & Asset Tag boardview and 450 G6 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we...
