Broken power input on portable dvd player
  • Leo.
    • Sep 2010
    I have this portable dvd player that I've had but didn't use for a long time. The problem is I went to plug in the charger, and noticed that there was a pin loose in the power input. It seemed to get broken somehow, it just fell out.
    I tried to plug in the adapter anyway but it didn't do anything. The power connection says "DC in 9v", it's pretty small. I tried to disassemble the dvd player and see if I could try and stick the pin back in, but I couldn't get it apart. I took all the screws out but it still wouldn't come apart, and I didn't want to force it.
    The question I have is if I was to get it apart somehow, would it be possible to just solder the pin back in? My soldering iron is kinda big also. I thought maybe I could just drop a bit of solder into the hole and quickly stick the pin back in, but that seemed like a bad idea.
    Maybe I can get a replace input? What should I do?
    It is a CyberHome Portable DVD Player CH-LDV 700B
  • retiredcaps
    • Apr 2010
    • 9271
    Re: Broken power input on portable dvd player
    DC jack replacement is a common thing for laptops. If you take apart your player you may be able to find an OEM DC jack replacement. If not, you may be able to find a laptop DC jack that may be a suitable replacement?
    DC jacks for laptops can be as low as $1.50 USD on ebay.
    --- begin sig file ---
    --- end sig file ---
    • Krankshaft
      • Jan 2007
      • 2328
      Not a chance in hell. You can never fix plastic components reliably just replace them. You need to replace the barrel connector by desoldering it and installing a new one.
      Search at Digikey for barrel connector you'll need to know the connectors inner diameter before ordering for example 2.1mm is a popular one.
      The case is probably held together by a combination of screws and clips it may require some pulling to dislodge them.
      • Leo.
        • Sep 2010
        Thanks for the replies,
        I'm a bit confused at the diameter thing, I took a ruler to it and it turned out to be about 4 mm. Now I did a search on digikey.com (I just did a general search because 4mm was not an option), and they all seem to be 2.1mmID-5.5mmOD...whatever that means. They aren't listing what voltage they are or anything like that so I'm just assuming it's like a universal thing?
        The good thing is they are only like $0.70
        • Quasar
          • Sep 2010
          • 132
          ID -inside diameter
          OD -outside diameter
          Measure the pin that fell out for the ID figure. Measure the plug from the charger for the OD.
          • warsztat
            HP 15-n070sw broken power input.
            by warsztat
            HP 15-n070sw (DAOU82MB6D0 REV.D) broken power input. Control pin short with 19V.
            Now, after plug power input led power button & power blink 13 times and light led power socket I start the laptop but no picture on screen only backlight light. The external screen connected via hdmi does not display either.
            I'm now wondering if a short circuit in the 19V socket could also cause the lack of image on the screen. Please rate and tell me what 13 flashes of the power LED mean.
            Sorry my english.
            01-03-2024, 06:52 AM
          • nervous_capybara
            Repairing the Hitachi DA-6000 CD player
            by nervous_capybara
            Hello everyone !
            I recently conducted maintenance on a Hitachi DA-6000 CD player for my grandparents : it had two distinct issues.
            Feel free to share your experience if you ran into other issues.
            DISCLAIMER : BE VERY CAREFULL WHEN OPERATING ON THIS SYSTEM : THE HIGH VOLTAGE IS VERY CLOSE TO THE VARIOUS TESTING POINTS, PROCEED WITH CAUTION
            CD tray would not come out of the player
            I could hear a motor spinning inside the player but the CD tray would not come out.
            Turned out that the issue was the CD tray belt that aged poorly and began to...
            11-05-2025, 03:11 AM
          • ugamazing
            820-02020 Super Weird Issue: Keyboard Input Character Map "Wrong"?
            by ugamazing
            So, I have a really bizarre issue that I'm struggling to identify the cause of. Working on an 820-02020 board with some bizarre keyboard/input-source character mapping. My suspicion is a possible damaged SPI ROM (U1970), perhaps, but I'm really not sure in this case:
            1. The issue is pretty weird, but when installing MacOS, I noticed my WiFi password did not work. I quickly realized the special characters (!@#$%^& etc) were not mapping correctly.
            2. I noticed the keyboard layout/input-source is defaulting to JAPANESE every single time I restore the board. I am not...
            04-10-2024, 08:06 AM
            MEDION AKOYA S15447 + ext. DVD Player Notebook Specification for Upgrade or Repair
            This specification for the MEDION AKOYA S15447 + ext. DVD Player Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the S15447 + ext. DVD Player boardview and S15447 + ext. DVD Player schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
            09-06-2024, 05:30 PM
            HP EliteBook 840 G5 + Samsung T5 250GB External Portable SSD + 15.6" Classic Briefcase & Mouse Notebook 800 Specification for Upgrade or Repair
            This specification for the HP EliteBook 840 G5 + Samsung T5 250GB External Portable SSD + 15.6" Classic Briefcase & Mouse Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the 840 G5 + Samsung T5 250GB External Portable SSD + 15.6" Classic Briefcase & Mouse boardview and 840 G5 + Samsung T5 250GB External Portable SSD + 15.6" Classic Briefcase & Mouse schematic. Our users have donated over 1 million documents which are being added to the site. This page will...
            09-06-2024, 08:52 AM
