I need UNI-T 260b firmware
UTİ 260B Thermal Imager
Re: UTİ 260B Thermal Imager
uni-t 260b firmware download <—(Google this )
https://www.uni-trend.com/html/produ...s/UTi260B.html
This is in the manual for this device
Is there a reset button on this device
“ To restore factory settings:
1) Press the up/down button to select the Factory Reset option in the System Settings
submenu.
2) Press the SET button to enter.
3) Press the up/down button to select Yes.
4) Press the SET button to confirm.
5) Press the back button to exit.
Note: During the factory reset process, please do not force other operation to avoid program errors.”Last edited by sam_sam_sam; 03-21-2021, 05:41 AM.9 PC LCD Monitor
6 LCD Flat Screen TV
1 Dell Mother Board
15 Computer Power Supply
All of these hadCAPs POOF
Originally posted by ay_bulut View PostI tried it because the menus are not visible
The software is some type zip file type that is unknown I can not unzip itLast edited by sam_sam_sam; 03-21-2021, 08:44 AM.9 PC LCD Monitor
1 Dell Mother Board
link below has video
https://youtube.com/shorts/mCEEwUoOahk
Originally posted by stj View Postpost the file
https://www.uni-trend.com/html/produ...s/UTi260B.htmlLast edited by sam_sam_sam; 03-21-2021, 01:44 PM.9 PC LCD Monitor
1 Dell Mother Board
How much of a charge does this unit have it could be that if it below a certain point it might not let finish booting but this is just a guess
But I have seen some devices do this where either it will not boot at all or it will only partially boot
Or there is something wrong with firmware installation or setup
If you can not figure out what going on then if this device is new get with the seller and find what can be done to resolve this issue9 PC LCD Monitor
1 Dell Mother Board
it's a RAR file, not a zip file.
install this for archive opening:
https://peazip.github.io/
no need for any stupid shit like patches or serials - it's open-source.
Hey Buddy! Did you found a Solution for your Problem? I have the same Problem. My UTI260b can't finish booting. With 100% he stops and that*s all. With completely low Battery i can start him somehow but not always. I have really no Idea what i can do and serching for new Firmware wasn*t succesfull. Thanks for Answer.
Originally posted by vitaliik View PostHey Buddy! Did you found a Solution for your Problem? I have the same Problem. My UTI260b can't finish booting. With 100% he stops and that*s all. With completely low Battery i can start him somehow but not always. I have really no Idea what i can do and serching for new Firmware wasn*t succesfull. Thanks for Answer.
Originally posted by Алекс View PostAlso such a problem. Did you manage to solve it?
I talked to the authorized dealer and they exchanged it for a new one.
Originally posted by ay_bulut View PostI talked to the authorized dealer and they exchanged it for a new one.9 PC LCD Monitor
1 Dell Mother Board
