What do you think of this iron suitability?
  • Agent24
    I see dead caps
    • Oct 2007
    • 5037
    • New Zealand
    I was thinking of buying a temperature controlled station as my current irons just don't have enough power for some of the boards with large ground planes.
    I went and re-read "The recapping FAQ" (https://www.badcaps.net/forum/showthread.php?t=485) to see what is best.
    A 60-watt iron at 450°C is specified and my current one is a Scope MH25 which stands for 25 Watt and I'm not sure what the temperature but I think it's only around 360°C
    Then I found this iron at Dick Smith: http://www.dse.co.nz/dse.shop/4b5539...uct/View/T2309 Which is 60-watt but runs over the recommendation at 470°C.
    Would this be suitable or is it too hot? Is a proper temperature controlled station a better idea?
    -David VanHorn
  • shadow
    • Feb 2007
    • 732
    Re: What do you think of this iron suitability?
    40-60W soldering irons are good for re-capping purposes.
    The ideal soldering temperature (and the temperature you should always solder at) is 350 degrees. For de-soldering, it can be useful to increase the temperature a bit to say 400 degrees.
    470 degrees is on the high side unless the temperature is adjustable.
    On the link it states:
    "This well built 60W soldering iron provides extra heat reserves for those larger jobs. With 240 Volt operation, 470°C operating temperature, long-life plated tip, lightweight handle and a mini soldering iron stand. Due to it's higher temperature and larger heat reserves, this iron should not be used for smaller components or PCBs."
    The part in bold I completely agree with, 470 degrees is a bit too hot for PCB work. DSE along with Jaycar do stock some reasonable soldering stations. They do cost much more than that iron thou.
    What is your budget?
    • Agent24
      I see dead caps
      • Oct 2007
      • 5037
      • New Zealand
      Why does Willawake recommend 450°C on his tutorial? or is it meant to say 350°C?
      There's only one soldering station DSE NZ sell which doesn't have a temperature readout. I wanted to get the T2250 but only DSE Australia sells it now.
      Jaycar NZ sells cheapest what I think is a Chinese ripoff of a Hakko, with probably too fine a tip and I can't see replacements on their site.
      Next one up is this: http://jaycar.co.nz/productView.asp?ID=TS1390 which looks interesting (But probably just more Chinese el-cheapo)
      The only other option is a $360 Goot.
      I'm just looking around and trying to work out what I actually need so I can get an idea of what the prices are. Not sure exactly what I want to spend, I guess $360 is on the high side but if it's worth it...
      -David VanHorn
      • willawake
        Super Modulator
        • Nov 2003
        • 8457
        • Greece
        450oC is for removing caps
        350oC is for soldering new caps. can solder new caps at 450oC. i often do but be quick. i think 3 seconds at 350oC is actual manufacturer recommended.
        • shadow
          • Feb 2007
          • 732
          I am simply an amateur/hobbyist solderer and my soldering iron barely gets used. I have a soldering station that looks exactly like this one:
          http://www.jaycar.co.nz/productView....T&SUBCATID=627
          You are correct..it looks like a chinese ripoff of a Hakko unit. However the one I have also is (the brand is Lukey). The manufacturers link to the one I have is:
          http://www.lukey.cn/english/products...p?ProductID=18
          They do have better models, however I got it on the local market for a really good price (I think AU$60). And for the amount of use it gets, it has worked a treat for several years now.
          However I had to replace their pencil tip for a 1.6mm chisel tip which works much better for soldering through hole components. Jaycar should sell the tips, any tip with a hollow centre (for the ceramic heating element to fit inside) should work fine. I got mine from DSE at the time. At that time they also sold what looked like the same model soldering iron.
          • Agent24
            I see dead caps
            • Oct 2007
            • 5037
            • New Zealand
            What do you think of the http://jaycar.co.nz/productView.asp?ID=TS1390 ?
            I'd prefer to have a temperature readout than just setting the control knob and hoping that it's correct.
            -David VanHorn
              • 31198
              omfg - what's your exchange-rate?
              i'v seen those for £60 uk
              btw, they dont have an earthed iron - but they work well - a friend has one.
              it's a dual-display - it tells you the set-temp and the current temp so you can see if it's still heating up.
              • Agent24
                I see dead caps
                • Oct 2007
                • 5037
                • New Zealand
                60 GBP = 135 NZD converted directly, And as you see the Jaycar one is $215. But every decent tool here is a ripoff (and even the cheap ones are too) Or at least, I can't find any shop selling them for a cheaper price.
                I have recently found it's cheaper to buy some computer parts\electronics from Hong Kong off eBay, than buy them locally... eg: You can buy ONE ATMEGA16 from Jaycar here for $30, and EIGHT of them from eBay for half that, postage included!
                I think SICOM sells Wellers for $450+ I'm sure this is also overpriced. The same shop also sells Aoyue SMD rework stations for $400, yet pretty much the same thing can be had on eBay, plus shipping, for about $160.
                I was tempted to buy an Aoyue Iron from eBay, but they're probably rubbish quality.
                I had not noticed that station was not earthed. I expect that would be a better feature to have than the temperature readout.
                So, can anyone recommend a soldering station that has:
                *Earthed Iron
                *Temperature readout so I know what is actually going on
                *Not cheap rubbish that will break in 1 year
                *Hopefully not a ripoff (though this may only be possible if I buy from overseas )
                -David VanHorn
                  • 31198
                  looking at your want's list - xytronic stuff.
                  me, i likre to make franken-tools
                  i use a chinese base - the model before the one you listed that was similar but used led displays, and a xytronics iron - i changed the socket on the base to fit the iron.
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5037
                    • New Zealand
                    This is a rebranded Xytronic, looks good (though it says isolated, not grounded) http://www.dse.com.au/cgi-bin/dse.st.../product/T2250
                    And it's even on special, but unfortunately it's in Australia...
                    Do you know of anywhere I can get Xytronics in New Zealand or if there's anywhere overseas that would ship them for cheap enough to be worth it?
                    -David VanHorn
